Revtek 3" / 1.5" AAL Lift Kit
Discussion in 'Suspension' started by BlkTaco47, Nov 2, 2016.
  1. Mar 27, 2017 at 8:28 PM
    BNTLYTACO
    BNTLYTACO Member
    2017 TRD Offroad
    From what I've seen on here anything over 2" in the front are gonna cause some issues
    smitty99 likes this.
  2. Mar 28, 2017 at 3:40 PM
    andyberrios
    andyberrios Well-Known Member
    Andy
    2017 Tacoma TRD Off-Road and 2003 Tacoma Pre-Runner limited
    Im also looking for a lift, approximately 3 inch would be perfect for me. Your saying that long term, on that lift he did, that it will give him a problem on axels? will a kit like this be worth a look, it has a lot of stuff that i think could prevent future problems...http://www.lowrangeoffroad.com/2005...hCQAv9xejGNxvYGKR7QCVLOcDGijttgSTBhoCitPw_wcB
  3. Mar 28, 2017 at 3:56 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    He means East Coast Gear Supply makes a replacement sleeve for your front differential carrier bearing. Which is needed if you lift your truck more than 2" If you don't do this. There is a 75% chance you can do real damage to your drivetrain. So seperatte from that kit you also need the ECGS sleeve.
  4. Mar 28, 2017 at 3:57 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My needle bearing failed with less than 2" of lift
    Roddy13 likes this.
  5. Mar 28, 2017 at 4:16 PM
    andyberrios
    Andy
    Ill be honest.. i don't know what that is, but ill search it up. I'm an occasional off-roader looking to become an avid one. I know almost next to nothing to lifts, except that suspension is better than body kits? basically what's the bare minimum i need for a lift to not harm my truck? is this kit i found good? i thought it was because it had those upper control a that i thought would stop the OEM ball joint from bending or wearing after being lifted more than 2 inches?
    effin_guido1226 likes this.
  6. Mar 28, 2017 at 4:16 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    You know a kit is good when it's an extra $40 to get replacement shocks...
    Diablo169, andyberrios and wirenut like this.
  7. Mar 28, 2017 at 4:29 PM
    wirenut
    Andrew
    NH
    98’ T4R
    Advice from one dude to another. theres a sticky at the top of the 3rd gen page titled "what you need to know about lifting your 3rd gen tacoma" the billstein kit is a sweet setup.
    Humboldt_Homie likes this.
  8. Mar 28, 2017 at 5:08 PM
    Humboldt_Homie
    Humboldt_Homie If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    I hear people say "leave the overload in". What is "the overload"
  9. Mar 28, 2017 at 5:17 PM
    smitty99
    Scottsdale
    You don't go buy a 1500$ set of golf clubs for your first golf lesson do you? Wheel the truck find the shortcoming and limitations based on your desires then add as needed. Then buy once cry once
    EngineMonkey and BNTLYTACO like this.
  10. Mar 28, 2017 at 5:23 PM
    andyberrios
    Andy
    thats very true and you're right. But i didn't only want a lift to go off-roading, i want one so i can fit 33's and a nice set of TRD pro wheels, and from what I've researched 33's will rub on stock height.
  11. Mar 28, 2017 at 5:40 PM
    smitty99
    Scottsdale
    33s are most likely going to require trimming. Lift alone won't do it to keep them from rubbing when wheeling. You'll also need UCAs, an alignment etc. Plan to spend 2000 to 2500 on lift and labor if you want to do it right the first time. I'd plan to spend at least 1500 in parts alone.
    andyberrios[QUOTED] likes this.
  12. Mar 28, 2017 at 5:50 PM
    andyberrios
    Andy
    okay, thank y'all, this really helped. Any more advice will be appreciated!
  13. Mar 28, 2017 at 6:08 PM
    effin_guido1226
    effin_guido1226 IG: effin_guido
    Matthew
    San Antonio, TX
    2016 Tacoma TRD Sport 4X4
    - N-FAB RSP front bumper - 3" Bilstein 5100 coil over & suspension up front - LR UCA's - OME AAL & suspension in back -Ion Alloys & 285's to sit on - Trail Gear Sliders welded to frame - Rago Bed bars & hilift
    @smitty99 is this due to the "taco lean" ?
    Also can i ask the shop im going to have install my lift do it ? knock it all out at the same time.
  14. Mar 28, 2017 at 6:27 PM
    smitty99
    Scottsdale
    Is what due to taco lean?
  15. Mar 28, 2017 at 6:38 PM
    #35
    effin_guido1226
    Matthew
    San Antonio, TX
    Why is this needed? Because lifting the truck causes wear on the needle due to the new angle? the factory one isnt built for that, so ECGS built one that is?
  16. Mar 28, 2017 at 6:41 PM
    #36
    wirenut
    Andrew
    NH
    98’ T4R
    A truck isn't designed to be modified. Generally yes.
  17. Mar 28, 2017 at 6:42 PM
    #37
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I'll quote myself. Start with the basic and go from there. Under 2" front and you'll be able to keep your factory control arms and still get your alignment number, or at least close. Rear 3 leaf add-a-leaf should get you to ~1 1/2" which would put you level with the front 2". 285's should fit pretty well.
    Search ECGS bushing. It replaces the Driver side CV Needle Bearing that has been an issue with Tacoma's for 22 years. Pretty easy to replace, just takes some time to pull the Drivers CV.
  18. Mar 28, 2017 at 6:44 PM
    #38
    effin_guido1226
    Matthew
    San Antonio, TX
    10-4
    buy the ECGS replacement its only $60 and will save a world of trouble down the road. simple
  19. Mar 28, 2017 at 6:45 PM
    #39
    wirenut
    Andrew
    NH
    98’ T4R
    Spend the money on the removal tool. You'll be glad you did.
  20. Mar 28, 2017 at 6:50 PM
    #40
    smitty99
    Scottsdale
    You have to pull tie rods I believe as well as the cv axle so you can do it at home but may need to.rent a tie rod puller. Or find a driveline/axle shop to do it. Have seen quotes range from 350 to 400 for labor on the bushing replacement.
