Revtek lift kit
Discussion in 'Suspension' started by 808Koma, Sep 6, 2008.
  1. Sep 6, 2008 at 3:48 PM
    808Koma
    808Koma [OP] Active Member
    Honolulu
    08 SPORT TRD 4x4
    [​IMG] zoom 2005-2008 Toyota Tacoma - Revtek Suspension Lift Kit
    I have an 08 DC trd 4x4 and would like to lift if for an affordable price, this kit i found on autopartswarehouse.com I just dont really know that much about lifting trucks this being my first one and all. there is also the option to just get the front set of this kit, then what do you do on the back, is that where the AAL comes in and i have read to make sure that you get a long leaf for a better ride. That revtek kit says its for 3 inches in the front and 1.25 in the back. wouldnt you want 3 inches all around, and what size tires could you get and not have to worry about rubbing or having to cut anything. what size are the stock tires? for whoever has answers for me i greatly appreciate the help
  2. Sep 6, 2008 at 4:11 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    i forgot to mention that when i was asking about the tire size, i have have the 17 trd sport rims, if anyone has a picture of a 3 inch lift sitting on those rims i would like to see it please and specified tire size, thanks
  3. Sep 6, 2008 at 6:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  4. Sep 6, 2008 at 7:27 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    alright thanks alot for the pictures here, i think that i am starting to make a final decesion on the lift, its looking like the toytec 3' inch and then as for the rims i am thinking about helo 835, and still trying to avoid trimming i think that a 32 should be good right
  5. Sep 6, 2008 at 7:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    There really isn't that much trimming and you can't even tell it is trimmed unless you look. Here are the pics of my truck and what I trimmed.
    This is the front you can see where I put the zip tie to keep the loose plastic back away from the tires.
    Here is the square knob in the front
    This is the little bit of plastic I cut to keep it out of the way when turning lock to lock while needing wheel travel.
    Keep in mind that tires aren't always as tall as the advertise, for instance mine are BFG AT they are supposed to be 33s but really measure 32.4
    Make sure to take some pics, were fanatics here. Nice choice in rims.
  6. Sep 6, 2008 at 9:43 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    thanks found the rims from another post talking about them and they looked sweet and at 121 a wheel for 17s cant go wrong. how big of a factor does the width of the tire have on trimming to. I have seen a few trucks out here that have nice lifts and then rolling around on these little training wheel looking tires
  7. Sep 6, 2008 at 9:53 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
  8. Sep 6, 2008 at 10:02 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    yeah that is exactly the info that i was looking for thanks, is that the toytec lift on there did you go with the medium duty coils and did you get the shocks that they suggest on there too for the front
  9. Sep 6, 2008 at 10:11 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Don't go with the Oem coils I did and I fine they sag a little.
    Go the step up I believe it is the 885
  10. Sep 6, 2008 at 10:15 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    yeah the medium coils come with the 885, did you do the light set
  11. Sep 6, 2008 at 10:33 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Yeah the oem. I'd go with the 885's. I didn't notice my ride getting any stiffer so I would imagine the 885's wouldn't me much different.
  12. Sep 6, 2008 at 10:47 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    yeah i was ready about them and it said in the prduct info that if you have a double cab to go with those
  13. Sep 6, 2008 at 11:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Damn I must have missed that, boy that sucks. lol.
  14. Sep 6, 2008 at 11:18 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    yeah it says get those for the DC and then they recommend the shocks but i dont know if that is needed, but just in case i am going to pick those up too i dont want to short something and do it wrong
  15. Sep 6, 2008 at 11:21 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    You should only go for the 885 for the doublecab if you are ready to upgrade your front shocks. The OEM's aren't gonna cut it. Go for the spacers or it's gonna be rough.
  16. Sep 6, 2008 at 11:24 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    here is what it says right off the kit, are you saying that i shouldnt get these shocks when i get the lift kit.
    *** PLEASE NOTE: 885 Coils are only recommended with vehicles that already have 110# additional weight due to installation of aftermarket bumpers/winches or to achieve a full 3" of lift on double cab models. For best ride quality we recommend OME N140S front shocks be installed (sold separately) with these coils.
  17. Sep 6, 2008 at 11:31 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have the TRD Belstein shocks with mine and I must admit I never saw those notes nore did they mention it to me when I was speaking with them on the phone asking what to get. Maybe that is something new, I know there were some guys on here that were planning on informint Toytec that the 884's started to sag.
  18. Sep 6, 2008 at 11:37 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    yeah that looks like that is what is being addressed, but i havent looked at the belstein ones yet as far as the shocks go
  19. Sep 6, 2008 at 11:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I just have the shocks that the TRDs have because I got the Spring TSB done.
  20. Sep 6, 2008 at 11:51 PM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    alright well i am still brand new to all this so what the hell is TSB
