Revtek lift kit
Discussion in 'Suspension' started by 808Koma, Sep 6, 2008.
  1. Sep 7, 2008 at 12:05 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    technical service Bulliten. The dealer admits some vehicles meeting certain specs have a problem and they fix it free of charge. Its not a recall. The rear spring tsb was a problem on some tacomas they would bottom out with just a few pound in the rear. Bottoming out would be when the frame hits the bump stops most often occured when passing on bumps. Our trucks came with 3 leafs in the rear well with the Tsb they would give you 4 springs per side. and you truck wouldn't bottom out. It also gave all non TRD trucks the Belstien shocks that the TRDs have. There is a bunch of info on the TSB just type that in the search. They were supposed to have fixed it by 08 You can check here there will be a list maybe even a sticky covering this topic.
  2. Sep 7, 2008 at 12:09 AM
    808Koma
    808Koma [OP] Active Member
    Honolulu
    08 SPORT TRD 4x4
    gotcha thanks for the clarification
  3. Sep 7, 2008 at 1:59 AM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    You should get the OME N140S's w/ the 885's. They are designed to compliment the OME 885's. If you keep the OEM (original equipment manufacturer) shocks, you will more than likely experience a rough ride because they do not have the right spring rate to match the 885's.
  4. Sep 7, 2008 at 10:19 AM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    Alright even if i have the bilstiens now, i totally forgot that my truck came with them
  5. Sep 7, 2008 at 10:21 AM
    RealSouthernPride
    RealSouthernPride Well-Known Member
    OEM bilstiens suck, just toy shocks with a bilstien sticker on them
  6. Sep 7, 2008 at 7:45 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I haven't had any problems with them (the shocks) Call Toytec yourself, or whatever lift kit you are going with. They will be very knowledgeable.
  7. Sep 8, 2008 at 10:59 AM
    808Koma
    Honolulu
    08 SPORT TRD 4x4
    alright i will check when it comes time, having to get the new shocks is going to up the lift another 268 but if it keeps the ride smooth then well worth it in my opinion
  8. Sep 10, 2008 at 9:22 PM
    rik121
    rik121 Active Member
    Oregon
    [url=http://www.tacomaworld.com/gall
