Revtek vs Tuff Country
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacowen, Apr 11, 2008.
  1. Apr 11, 2008 at 8:03 AM
    tacowen
    tacowen [OP] Member
    Fort Mill, SC
    07 4wd 4door
    20" rims, new stereo system throughout
    i am going to put a 3" lift on my 07 tacoma. i am torn between the cheaper tuff country lift and the more expensive revtek lift with diff. spacers and a few other goodies. can anyone help me decide which is better?
  2. Apr 11, 2008 at 8:37 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Toytec is another option for around $240. They use billet aluminum for the spacers so they won't crack like the Revtek ones might. IIRC, the Revtek ones are some sort of plastic/polymer.
    Don't know anything about the Tuff Country one. HTH! :D
  3. Apr 11, 2008 at 8:43 AM
    tacowen
    tacowen [OP] Member
    Fort Mill, SC
    07 4wd 4door
    thanks! i'll check out the toyotek.... anybody else wanna chime in on this?
  4. Apr 11, 2008 at 9:19 AM
    tacowen
    tacowen [OP] Member
    Fort Mill, SC
    07 4wd 4door
    does anybody recommend the 3" coil plate extension by toytec as opposed to the replacement 885 3" coils from toytec? (pro basic kit vs lift coil kit?)
    i just need to make sure i get a solid lift that won't destroy my ride and handling
  5. Apr 11, 2008 at 10:48 AM
    FamouzStarz
    FamouzStarz NMSAF!
    18 TRD PRO
    KING type build
    my revteks are not plastic or polymer, although they are powder coated :)
  6. Apr 11, 2008 at 1:00 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Thanks for the info. I couldn't remember. I know someone uses plastic.
  7. Apr 11, 2008 at 1:50 PM
    tacowen
    tacowen [OP] Member
    Fort Mill, SC
    07 4wd 4door
    Yeah... i talked to a guy at toytec.... they and revtek are billet aluminum. i think i am going to go with the toytec 3" spacers and the add-a-leafs and the diff drop kit. thanks for the help i'll post pics when i get a chance.... it already looks sick with 285/50/20's which nobody said would fit..... but they do!
  8. Apr 11, 2008 at 4:57 PM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
    Def man post some pics of your rig when its done!
  9. Apr 11, 2008 at 6:54 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Good choice on going with Toytec. Did you get the Coils as well?
  10. Apr 13, 2008 at 2:04 PM
    tacowen
    tacowen [OP] Member
    Fort Mill, SC
    07 4wd 4door
    no coils, just the front spacers and rear add-a-leafs, diff drop kit, axle shims.
    the toytec rep talked me out of new coils.... said they would be too stiff, and with only a 3" lift, the aluminum spacers wouldn't be an issue.
