Revtek w/ 33's installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcboss, Dec 30, 2007.
  1. Dec 30, 2007 at 2:27 PM
    tcboss
    tcboss [OP] Well-Known Member
    Wilmington, NC
    Black Mamba
    3 in. Revtek Lift, 33 in. M/T Open Country's,
    a just got my 3 inch revtek lift installed looks great i am very impressed with it i still have my stock tires on since i was suppose to recieve my 33 inch mud terrains with 18 inch Goliaths on friday but they didnt come in time so i will be getting them on wensday when the mail starts back up...ill post pictures once i get it all set up........i had les schwab install my lift but im installing my tires and to install them u just use the lift thing unscrew the lugs and pop them new ones on right then screw the lugs back on? lol. thanks for anyhelp.
    thanks will
  2. Dec 30, 2007 at 4:32 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Keep enough pressure on the existing tires to break the lugs loose then lift up enough to remove the existing tires, also high enough to install new ones. Get the new rims on, thread the lugs on, making sure the rim "seats" on the axle, snug them with the wrench, lower vehicle on ground, full pressure and then tighten, drive for about 10 miles , stop and re-check the lugs, good to go. :D
  3. Dec 30, 2007 at 9:45 PM
    tcboss
    Wilmington, NC
    Black Mamba
    alright sounds good thanks
    yes les schwab did the whole alignment when they installed the lift
