RF backup camera...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, Aug 12, 2008.
  1. Aug 12, 2008 at 3:33 PM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    2020 Off Road
    Has anyone tried to use one of those new fangled RF backup cameras in their Tacoma? That would save running a video cable all the way to the front of the cab. Power is still required and I bet that can be picked up somewhere closer to the tailgate, perhaps the trailer wiring?
  2. Aug 15, 2008 at 12:42 AM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    The video quality looks much better if you just run a cable. It takes less than an hour to run a wire from inside the cab and down the frame rail. Just follow all the rear tail light wiring. The wiring is behind the kick panels, under the door sill, and then heads under the drivers seat and out through a grommet and then down the frame rails to the rear.
  3. Aug 15, 2008 at 4:16 AM
    Addicted
    Addicted Well-Known Member
    Greenville, SC
    07 DC 4x4 - TRD Off Road - Black
  4. Aug 15, 2008 at 3:46 PM
    45longcolt
    DFW Area
    2020 Off Road
    I have seen them cheaper than that but then again that one has a very easy mounting system and is adjustable vertically too. They gave no specifications for the image quality but it is built as a "vehicle" camera and should be a little more tougher than a camera NOT meant to be vehicle installed. The reviews were great, hopefully someone here has got one and will chime in. :)
