RFCC TTG2 + Rigd Rear Cam + Front Cam Wiring questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seidita84t, Jan 9, 2022.
  1. Jan 9, 2022 at 3:42 PM
    seidita84t
    seidita84t [OP] Well-Known Member
    2017 Quicksand DCLB TRD offroad
    Hey all those who may have some experience here.
    I've racked my brain about this, and typically have no issues figuring stuff like this out, but I have to admit, that I'm a bit lost.
    I recently picked up a Germes Labs camera control module, as well as a Rigd Ultraswing with the camera relocation kit. And in the process decided to grab a Natika camera to mount up front in the truck.
    I'd see this being pretty simple if just adding the rear relocation cam, or just adding the front cam, but now I'm confused with both, and wanting to retain function of the OEM camera for the few times when the UltraSwing isn't mounted.
    The Germes module has 2 camera inputs, and 2 power outputs. One power designated for 12v, the other for 6v.
    I know the Natika for the front is 12v, and I'm 99% sure that the camera on the UltraSwing is also 12v.
    From my understanding, the RFCC would typically retain the OEM rear camera on it's original circuit (aside from it being passed through the module), and when someone adds the front system, they'd use the 12v circuit from the RFCC. Then cycle between front and rear cameras.
    I believe when folks are using the Rigd kit along with whatever type of camera control module, they're using what would essentially be the "front" camera circuit on the control module, and then being able to cycle between the OEM rear cam, and the new relocated rear cam.
    Wanting to have all 3, would I use the same 12v out circuit from the module, and just have both cameras powered/triggered from there? Or would that present an issue with the module knowing which to display since they're both receiving power?
    I hope I'm articulating this question correctly. Thanks in advance.
  2. Jan 9, 2022 at 6:31 PM
    Taco-piper
    Taco-piper Well-Known Member
    2016 Tacoma OR 6MT
    Could you add the plug to each of the rear cameras that you'd switch between the two when you install or remove the Rigd? I'd out this under the bed for ease of install so you don't have to route another cable through the cab grommet.
    I used this connector when I installed a tailgate lock actuator so if I ever removed the tailgate it'd be a simple unplug. Hopkins 47965 2-Pole Flat Extension https://www.amazon.com/dp/B0002Q80RW?_encoding=UTF8
    Haven't had any problems for 3 years with it under the truck.
  3. Jan 9, 2022 at 7:13 PM
    seidita84t
    The camera on the ultraswing has the typical tiny round 4-pin connector that I can use as a disconnect when I take it off. I looked at the oem connector to see if I could make a plug to swap around sort of like what you're referring to, but haven't had the time to look at the wiring diagram to see which wires are power/ground and which ones are signal. Or determined where I can snag a connector/pigtail to use.
  4. Jan 9, 2022 at 7:16 PM
    Taco-piper
    2016 Tacoma OR 6MT
    I didn't think about how many wires it'd need. A flat 4 pin trailer plug would work then. Keep us updated, I've been looking at a swingout for my rig and will likely do the same to switch between both rear cameras and already have a front.
  5. Jan 9, 2022 at 7:33 PM
    seidita84t
    The other problem with doing this, is that I'm fairly confident that Toyota oem back up cameras are 6v. So I don't think you can actually "swap" between the cameras. The normal rig'd relocation kit uses a T-harness behind the radio and pulls 12v from there and uses it for their included camera. They have a newer kit now that includes a 6v camera and an oem connector but it's pricey. https://www.rigdsupply.com/products/tailgate-camera-relocation-kit-tacoma-tundra
  6. Jan 9, 2022 at 10:22 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
  7. Jan 9, 2022 at 10:34 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  8. Jan 10, 2022 at 9:22 AM
    seidita84t
    Ah thanks! Useful pinouts for that connector.
    Interesting, post #22 says/shows that they tried hooking the natika straight to the factory harness (which is 6v) and it worked. I'm going to have to test this. If that's the case, I do have an additional 6v output from the RFCC. The natika sheet specifies 12v, but a lot of DC items like that can operate within a broad range. Hopefully this works. Thanks again for the reference.
  9. Jan 10, 2022 at 9:25 AM
    shaggy135
    I can double verify that the factory harness works too. I made a 2nd camera harness with a Natika camera and that 4 pin plug that I'm going to use on my high clearance rear with tire carrier. Works like plug and play.
  10. Jan 10, 2022 at 9:47 AM
    seidita84t
    Fantastic. Much appreciated.
  11. Jan 10, 2022 at 2:35 PM
    seidita84t
    Would you be able to confirm if that was the 10942 connector/pigtail?
    You folks were spot on, and the Natika cameras operate just fine on the 6v output from the rfcc. Except, it seems like I can't have a camera hooked up to the "rear" input on the rfcc at the same time as the oem camera. When I do, I get a mixed screen of both camera images.
    Unless I'm missing something here, it looks like the rfcc will only allow me to operate 2 cameras, including the oem if it's hooked up. And I'll need to go the swappable harness route for the rear.
  12. Jan 10, 2022 at 3:06 PM
    shaggy135
  13. Mar 29, 2024 at 6:13 PM
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    Any success? I’m thinking of adding a front camera, but would be cool if I could add an additional camera on my trailer. Since with the oem camera I just stare at my trailer hitch. Haha
  14. Mar 29, 2024 at 7:59 PM
    caribe makaira
    Caribbean, Puerto Rico
    You could add a harness to the rear bumper camera connector that would reach the rear of towed trailer.. Typically the Taco comes with a connector cover for when you require to remove the tailgate. You'd just disconnect the harness to the tailgate and cover the connector (tailgate side) and connect the added harness when you hitch the trailer.
  15. Mar 31, 2024 at 4:41 PM
    Mr. Excitement
    J
    So make like a pigtail on the tailgate harness? Then when tow plug it in? Would I need to unplug the connection to the main tailgate camera?
  16. Mar 31, 2024 at 5:10 PM
    caribe makaira
