Ride Quality of 22s
Discussion in 'Wheels & Tires' started by PatheticJoe, Oct 12, 2007.
  1. Oct 12, 2007 at 9:42 PM
    PatheticJoe
    PatheticJoe [OP] Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    I'm pretty firm on putting a set of 22s with 285/35s on my Prerunner but I've read a lot of negative but not very specific comments on numerous other threads about the ride quality. Can someone give some detailed comments on the ride quality. Too stiff, noisy, etc... I'm also interested in the positive ones since I've seen a lot trucks with 22s on this site.
    Thanks, Joe
  2. Oct 13, 2007 at 9:18 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i would go w/ a lil more rubber around that rim. i had 18's w/ 255/45's on it and it rode like shit...i put some 55's on it and it rode a lil better
  3. Oct 13, 2007 at 12:01 PM
    PatheticJoe
    Sacramento, CA
    What does this mean!!! stiff, felt every bump, had to drive slow, other?
    Joe
  4. Oct 13, 2007 at 12:51 PM
    The_Hodge
    SC
    felt every single lil bump...had to drive slow...plus if u have a front lift spacer, it'd look retarded to get big rims w/ no rubber to fill in those fenders...even on stock setups
  5. Oct 13, 2007 at 2:58 PM
    PatheticJoe
    Sacramento, CA
    Jhodge83 - Thanks for more specifics. I might go with 20s and 285/45s or so, hopefully some other folks will chime in.
    Joe
  6. Oct 14, 2007 at 8:05 AM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    big rims might look good but ride shitty i would go with 20's to keep some rubber in the ground
  7. Oct 14, 2007 at 9:14 AM
    rick
    rick `
    go with 285/50. i had those are my truck and are still for sale including the wheels
  8. Nov 17, 2007 at 2:40 PM
    20Tacoma05
    20Tacoma05 New Member
    Oxnard, CA
    2005.22inchweels.BorlaExhaust.PioneerDVDindash.2subs.2amps.4260watts.SingleCab.
    22inch wheels, pioneer dvd indash, 2 12 inch subs, 2 amps, 4 speakers,4260 watts of power in a single cab.
    22's are fine as longs as you get the right width and tire size for your tacoma. I have a single cab 2005 tacoma and its stock height. I have 22x7.5 rims on it. the tire i have is the 2453522. The truck rides very well. But you will notice a diffrence in acceleration. Your truck should be fines as long as you go with a 22x8.5 or 22x.9. the tire size you should go depends on ur truck height and width of ur wheel. your local tire shop should be able to tell you. Just make sure you get your wheels balanced and take that bad boy for alignment also. You should be set.
  9. Nov 17, 2007 at 6:00 PM
    PatheticJoe
    Sacramento, CA
    I'm glad somebody had a positive experience with 22s. I've really been looking more at 20s lately and the price difference is now starting to play into it and the 20s are much cheaper. I'd still love to put a set of 22s on but I think for the price and the ride 20s will likely be the choice. I'll probably buy them in February.
  10. Nov 17, 2007 at 6:20 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    If you google "tires" there is a tire calculator on one of the pages which could assist you in your purchase, it figures your speedometer at sixty mph, shows how far off you would be, could help you with "Johnny Law".
  11. Nov 17, 2007 at 6:24 PM
    PatheticJoe
    Sacramento, CA
    Thanks, I was actually planning to have the speedometer recalibrated. This can be done right?
  12. Nov 17, 2007 at 10:29 PM
    morcheez
    morcheez Well-Known Member
    San Antonio
    05 XRunner BSP
    A BUNCH
    hah u guys got nothing on me ...255/35/20's and i dont think its that bad ...just get a nice size sidewall and u should be fine with 22's
  13. Nov 18, 2007 at 8:58 AM
    PatheticJoe
    Sacramento, CA
    Morcheez, thanks for posting your black Xrunner has a very similar wheel to the one I've been considering. Black with machined lip. Any regrets with the choice? Would you buy the same wheel again? I'm also glad you don't think the ride is that bad. I think I have to suck it up and go 22s, if everything goes right I'll have these wheels for a long time.
  14. Nov 18, 2007 at 8:00 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I have a feeling that the ride on an X with 22's compared to a PreRunner with 22's will be vastly different because of the suspension characteristics of each truck, but that's just a guess...
  15. Nov 19, 2007 at 3:24 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    It all has to do with the side wall of the tire. If you running a 275 width tire and a 30 aspect ratio side wall your ride will stink if you run a 50% aspect ratio side wall the ride will be just likt stock.
    275-60-r17
    275 width of tire in mm's 24 mm's about 1 inch
    60 means you side wall is 60% of your width
    17 rims size
  16. Nov 20, 2007 at 9:12 AM
    morcheez
    San Antonio
    05 XRunner BSP
    A BUNCH
    true but i would also thing an xrunner that has been lowered like mine would ride alot worse with the tiny tires i have...and it doesnt bother me a bit ..and it should be better for him ...at least i think :confused:
  17. Nov 20, 2007 at 9:14 AM
    morcheez
    San Antonio
    05 XRunner BSP
    A BUNCH
    no regrets at all....i love my wheels and got them at a great price (1400 rims/tires) ..good luck with your choice
  18. Nov 28, 2008 at 10:28 PM
    gegundez
    gegundez Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    I saw a couple of Tacos with 22s and they look awesome. Though I have to think that the ride must really suck. I have had many ricers (Miata, Civic EK, Accord, Civic CRX) with 40 series tires and so I am planning on getting some Tundra Deep Six 20s with 33" 275/60/20 tires. Still looks good and rides like stock. :D
  19. Nov 29, 2008 at 1:49 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I agree the narrower the sidewall the worse the ride. I have 265/50/20's and the ride is pretty good. When I was looking at tires, I thought of going with a 45. But all the tire places said the ride will be rougher if I go smaller sidewall, Less flex to help absorb bumps.
  20. Nov 29, 2008 at 3:26 AM
    Smurfio18
    Smurfio18 Well-Known Member
    Northridge
    06 Tacoma TRD PreRunner
    I keep it Stock but Clean!
    I had 20's on my truck and hated it. I was also running a 35 profile tire and had to go slow over every bump. Twice I hit a pot hole and it dented my rim and let all the air out of the tire. I then had to send out the rim to be straightened. I wouldn't recommend bigger rims on a truck, defeats the point in having a truck if you know what I mean.
