Ride Rite airbags....highly recommended!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Mar 15, 2011.
  1. Mar 17, 2011 at 7:41 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Not so easy to add air, plus what about when the truck has cargo in it, and you want to add more air?
  2. Mar 17, 2011 at 7:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good point... and something I didn't think about at all :eek: I have a cap and use mine mostly for towing so that situation didn't even occur to me but I could see loading a bunch of soil in the bed and being pissed 'cause I couldn't get to the air bag fillers.
  3. Mar 17, 2011 at 8:05 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  4. Mar 17, 2011 at 8:30 AM
    Pugga
    Massachusetts
    Not 100% sure if that'd be a good idea. In theory, it should work, line pressure is line pressure but, if you install as intended, you get 2 stand alone, pressure locked systems. If you T them together, air volume could go back and forth between the 2 sides. It would do nothing to steady a load side to side (say when cornering). I'd leave the 2 sides independent.
  5. Mar 17, 2011 at 8:37 AM
    David K
    When mine was installed, I wondered the same thing... and realized if the manufatorer didn't design them to be filled together from one valve, there had to be a good reason. If one tube breaks... you only loose one bag instead of both, for example.
  6. Mar 17, 2011 at 9:08 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Sounds reasonable
  7. Mar 17, 2011 at 9:15 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    put the valves in the gas door
  8. Mar 17, 2011 at 9:18 AM
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    The compressor kits come with Ts allowing the use of one gauge to monitor both airbags, as well as fill them. Therefore i would say it's possible.
    Here is one of many examples:
    http://www.suspensionconnection.com/cgi-bin/suscon/2158.html
    "Single gauge control ties the two air springs together providing equal inflation of both air helper springs. Ideal for towing or hauling centered loads."
  9. Mar 17, 2011 at 9:25 AM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    I've had mine tee'd together for 3 years and never had a problem. The only advantage to keeping them separate is if you haul severely uneven loads.
  10. Mar 17, 2011 at 9:49 AM
    Pugga
    Massachusetts
    That centered load thing is what would worry me. Your truck is moving and every time you take a turn, there's a lot more stress on the outside bag. If the system is T'd together, it was just collapse and the air would rush to the inside bag causing that infamous 'truck roll'. You'd then just be relying on your stock suspension to counter the truck roll effect. You could always valve it so it would be a little harder to rush side to side, like the way they'd valve a shock. I'm not sure how difficult that would be do do though, or how much of a concern the cornering really is. It's not like you'll be racing when fully loaded anyways... I'm curious about this and just thinking out loud hoping it triggers some thoughts from others on this.
  11. Mar 17, 2011 at 9:55 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Personally I am going to the junk yard and rip a ride level package and compressor out of a caddy or other top end GM car and install it in the Tacoma. It is not had to do and will only cost around $20.
  12. Mar 17, 2011 at 10:08 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Yeah, I'd think you wouldn't want to T it, because separate you can balance an uneven load.
    Do any of you guys with the bags jack the truck up on the side by the frame?
    I do this everytime I rotate tires, and from what I understand it is a big no no with bags.
    I'll proabaly wind up getting them anyhow, because I WILL have a boat this year.
    Dealer won't do the TSB for me, and I don;t feel like screwing around now that I have an AAL installed.
    But last summer when I towed a little 16 ft fishing boat, my ass was sagging bad... emabarrassing...
  13. Mar 17, 2011 at 10:26 AM
    Cogge89
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    They need to be deflated before being put on a lift, or jack.
  14. Mar 18, 2011 at 6:19 AM
    MikeF
    MikeF Active Member
    Newfoundland
    09 SR5
    3" Lift Morimoto Mini D2S bixenon retrofit 265/75/16 motometal 951b satoshi Alpine IXA-W404 + components
    Good question, I haven't seen yours either. I guess we are the only two nuts with M's for sure. You commented on my truck on lewishillbillies actually, I haven't signed up for sled headz i probably should. I've got the morimoto minid2s retro done now as well. Be nice to see your truck sometime and compare some mods and check out eachother ride! what side of town are you on?
  15. Sep 25, 2014 at 6:22 PM
    #35
    Shade
    Shade Member
    Chesapeake, Va
    4X4 TRD Off Road Edition
    Toyota TRD exhaust, 1" lift via Bilstein 5100's (can't go too high... tree branches!), Nitto Terra Grapplers, Undercover tonneau cover,
    In my opinion I wouldn't mount the schrader valves inside the small rear compartment because you might need to add air when the bed is full (ie gravel, mulch, etc).
