Right filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Vern28, Sep 8, 2018.
  1. Sep 8, 2018 at 4:16 PM
    Vern28
    Vern28 [OP] New Member
    2003 Tacoma 4x4
    What is the Toyota oil filter number for a 3.4L that is in my Tacoma ?
  2. Sep 8, 2018 at 9:17 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    90915-YZZD1 is your OEM filer.
    There are other filters that also would fit and work fine (such as the YZZD2 and YZZD3), but are on the side of spending more for more filtration that's likely unnecessary for our trucks as they are made longer to accommodate newer gen Tacomas.
    Also to note, all 1st gens use the YZZD1 filter from 2.4L, 2.7L, to 3.4L
  3. Sep 8, 2018 at 9:18 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  4. Sep 9, 2018 at 9:32 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    I buy Toyota filters from the dealer. This time they gave me the D3 instead of the D1. So how much larger is it then the D1 in terms of oil capacity?
  5. Sep 9, 2018 at 9:50 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The D3 is about 9/16" longer, might hold all of an ounce and a half more than the D1. Depending on the type of filter wrench used, the engine oil cooler hose (if equipped) can get in the way to a degree. I also have a 4.0L and wanted to "stock" just the D3 but it was not worth it for me.
    Fatal_Paradox[QUOTED] likes this.
  6. Sep 10, 2018 at 12:49 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I use the D3 but really you are not going to tell a difference in oil capacity. I paid $25 shipped for 5 of them with new drain plug gaskets (not that I care about the gaskets). Even cheaper if you buy 10 of them. D1s are a tad bit cheaper. Either one will perfectly fine, no reason to loose sleep over which one to use.
    Fatal_Paradox likes this.
