Right HID not turning on
Discussion in 'Lighting' started by pamantea, Oct 1, 2013.
  1. Oct 1, 2013 at 2:16 PM
    pamantea
    pamantea [OP] Well-Known Member
    British Columbia, Canada
    TRD Exhaust
    Hey guys,
    I have had the HID's from DDM Tuning in my truck for nearly two years now without many problems until recently. I have the HIDs in the headlights, fog lights, and in my grill in some hellas. The lights in the grill are controlled on a completely separate switch. Recently, I noticed my right headlight (right from sitting in vehicle) not working. I replaced the light, no change. Replaced the ballast, no change. I turned the switch off and then back on, and it turned on. Thought it was strange. Now, the light will only turn on about 60-70% of the time when I turn my lights on. I can literally turn my lights on and off and sometimes the right light will turn on, sometimes it wont. Does anyone have any ideas??
    Thanks!
  2. Oct 1, 2013 at 2:23 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Could be a grounding issue?....have you looked into that?
  3. Oct 1, 2013 at 2:28 PM
    pamantea
    TRD Exhaust
    Ahh, good idea. How should I best tackle that? And why now over two years? Would rust or grime just have built up?
  4. Oct 1, 2013 at 2:30 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah its very possible. I'm not sure how your setup is but I have seperate grounding wires for each of my HID headlights off the ballast I believe so try and check that. I've had grounding issues before where it wasnt making good contact.
  5. Oct 1, 2013 at 2:38 PM
    pamantea
    TRD Exhaust
    Ok. I will check both and clean the spot and wire again to ensure contact. Thanks for the advice. hopefully that solves the problem!
  6. Oct 1, 2013 at 2:46 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Let us know if that solves it. ;)
  7. Feb 26, 2014 at 6:34 PM
    pamantea
    TRD Exhaust
    Hey, So I still have not been able to solve this. I have tried changing the ground twice, and just when I think it solves it, it goes off again. Today I tried stripping the wire back and putting a new ring terminal on it and drilling a new ground which was close to a different ground. It turned on, but when I started my truck, it turned off while the left one stayed lit. I turned the lights on and then off again and it worked. Ideas??
  8. Feb 26, 2014 at 6:46 PM
    pamantea
    TRD Exhaust
    Could it possibly be the relay?
  9. Feb 26, 2014 at 6:50 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    if it was the relay, both would probably have gone out
    I've had two relays take a dump on me and they left me with no lights at all
    try swapping ballasts, they can go bad after awhile
    edit:
    just reread OP.. ballasts werent it eh
    sounds like a ballast problem though...
  10. Feb 26, 2014 at 6:52 PM
    pamantea
    TRD Exhaust
    no, unless the ballast i used to replace it with was bad too. Unlikely I think!
  11. Feb 26, 2014 at 6:54 PM
    pamantea
    TRD Exhaust
    Maybe I should try running the ground right to the battery?
  12. Feb 26, 2014 at 6:57 PM
    SeminoleTRD
    SeminoleTRD Well-Known Member
    James
    Fleming Island
    2008 TRD Sport DCLB
    3" ProComp Add-a-leaf, 1.5" SpiderTrax, Center Bearing shim, Nitto TerraGrappler 285/70R17, Volant Air Box, BakFlip Tonneau HD, DIY 3.5mm AUX Jack install, D-Ring bed mounts, Plasti-Dipped badges, Dumped 50 Series Flowmaster with DeltaFlow Tech, Lumen LED Fog Lights, Lumen Marker Lights, Spyder Smoke Headlights, Satoshi Grill, Anytime Fogs
    Unless you got bad ballasts back to back. If possible, swap a known good ballast and bulb, say driver side to passenger side. If the problem continues then there has to be a short somewhere. Either a wire is stripped from rubbing against an edge or something and is drawing power away from the ballast causing it not to cut on. My HIDs did that before and I traced wires. I hope it's a quick and easy fix.
  13. Feb 26, 2014 at 6:58 PM
    InSight Retrofits
    InSight Retrofits Closed
    Mine was out the other night and I was like damn another bad ballast! Swapped ballast and same thing.
    Traced it to the ground wire and the bolt I used to hold the ring terminal in actually broke :confused:
  14. Feb 26, 2014 at 7:07 PM
    SeminoleTRD
    James
    Fleming Island
    2008 TRD Sport DCLB
    Ya, try and bypass all the switches and relays. Run the ballast straight off the battery.
