Rigid 20" Led Light Bar Stealth Mounted Questions???
Discussion in '3rd Gen. Tacomas (2016+)' started by SoFlaTacoTRD, Jun 15, 2016.
  1. Jun 15, 2016 at 9:30 AM
    SoFlaTacoTRD
    SoFlaTacoTRD [OP] TRD Taco'd
    SoFla
    2016 Tacoma TRD OR 4x4, ACLB, Quicksand
    I'm looking to install an LED light bar in my lower grill but only want a 20" light bar and have decided on the Rigid E 20" Combo.
    Question 1- Does anyone make a "stealth" mounting solution for this specific length light bar?
    Question 2- Who makes a switch that looks like factory? I intend to put the switch next to the inverter switch.
    Question 3- I also intend to mount a hidden winch using HEFTYfabworks mount, will there be a mounting conflict with the LED light bar?
    Thanks!
  2. Jun 15, 2016 at 10:14 AM
    ale214
    ale214 Well-Known Member
    Chatham, IL
    2016 OR 4x4 White
  3. Jun 15, 2016 at 10:37 AM
    SoFlaTacoTRD
    SoFla
  4. Jun 15, 2016 at 1:10 PM
    ale214
    Chatham, IL
    2016 OR 4x4 White
    That is a good question. Mine is on my living room floor with the light pending my bamf grill. Trying to knock out 2 things at one time once i get it.
  5. Jun 15, 2016 at 1:24 PM
    SoFlaTacoTRD
    SoFla
    If you would please let me know about the backlight color and if it's dimmable once you get 'em installed? :thumbsup:
    I did find out from Chris @HeftyFabworks that NO, there is no room for a light bar in the lower grill once the winch is in place. I don't like hearing "no" so I will have to determine how to MAKE a light bar fit there with a winch.
  6. Oct 16, 2016 at 12:14 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Have you looked at the Revtek mount? It's not super stealth, but puts the bar higher above the front bumper and may work with that winch.
  7. Oct 16, 2016 at 11:13 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    as far as air on board, no. backlight isn't same as the dash. it's a lot more blue. more close to the "d" in the shifter indicator in the center console. and it's not dimmable.
  8. Jan 12, 2017 at 1:17 AM
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    OP did you end up getting a light bar?
