Rigid light build
Discussion in 'Lighting' started by masterwacker, Nov 25, 2012.
  1. Feb 4, 2013 at 5:15 PM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Nice, they look really clean. Those are the same tires I plan on acquiring in march, any rubbing issues if you don't mind going off topic real quick?
  2. Mar 25, 2013 at 7:20 PM
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    Not much.
    Awesome job brother. Looks great
  3. Mar 25, 2013 at 7:25 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Most light! I want a roof light bar so bad. But everyone is getting them now.
    I love yours though.
  4. Mar 26, 2013 at 9:03 AM
    Datsik
    Anthony
    San Diego
    Not much.
    X2
  5. Mar 26, 2013 at 7:43 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Holy LED batman!!!! Looks great!
  6. Mar 31, 2013 at 8:41 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    What light switch set-up are you running in the truck for your SPOD? Been thinking about an overhead console since my TRD OR doesn't have but two dummies which would have been for the heated seats.
  7. Jun 7, 2013 at 9:16 AM
    XIGUNHAWKIX
    XIGUNHAWKIX Just a desert dude.
    Luke
    Taos, NM
    SR5 4WD Base Project Truck
    Entune touchscreen display, JBL system, blacked out, Icon 2.5 Remote Resis, TC UCA's, 50" LED LightBar. Pelfreybilt bumper.
    Nice write up, truck looks great man.
  8. Jul 28, 2014 at 2:20 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Awesome write up!!!
    Do you think I could make a 40" radius bar fit the same? Obviously the bar mounts would be angled some. But do you see any reason why it wouldn't work?
  9. Oct 14, 2014 at 7:57 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Hey Paul, Do you get any wind noise (or other noise) from the LED lightbar mounted to the roof rack?
  10. Dec 30, 2014 at 7:41 PM
    masterwacker
    masterwacker [OP] Well-Known Member
    Paul
    Orlando
    2010 Tacoma TRD Off Road
    TRD Sport hood, TRD Sport paint matched rear bumper and grill, BDF grill light bracket with some Rigids, 40" Rigid roof bar, SPOD, Stereo, Pro Comp Prorunner front strut lift and rear shocks, PXA 7036 Wheels-285/70R17 BFG AT/KOs and some other stuff
    No wind noise at all.
  11. Mar 1, 2015 at 8:50 PM
    RigidIndustries
    RigidIndustries Built To Be Seen
    Gilbert, AZ
    Paul, your build is crazy impressive! Informative and thorough thread also!
    Thank for choosing Rigid for all your lighting needs!
    Cheers!
    ChadsPride likes this.
  12. Dec 18, 2015 at 6:46 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    :facepalm:and here I am thinking of taking a quick trip to home depot, buy a thick piece of flat metal, shape it with my dremel, drill a couple holes, mount to the roof rack and mount the led bars. yea looks like its a bigger project than what I was expecting
  13. Dec 18, 2015 at 6:05 PM
    4x4Taco09
    Dane
    Louisiana
    Thats what I did ;)
    ChadsPride and Byb127 like this.
  14. Dec 20, 2015 at 7:08 AM
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    Dane is that a 40" led also?
  15. Dec 20, 2015 at 7:18 PM
    #35
    4x4Taco09
    Dane
    Louisiana
    Described as a 42.5"
    RedBeard1 likes this.
  16. Dec 28, 2015 at 11:34 PM
    #36
    AKK
    AKK Well-Known Member
    Alexis
    Santa Barbara, CA
    2014 TRD Off-Road
    Am I doing this right?
    Nice lighting. Does the mesh from the grill noticeably obstruct light? Debating between a mesh grill or rigid's grill.
  17. Oct 18, 2017 at 5:12 AM
    #37
    tacos_modern_life
    tacos_modern_life Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    Dang I want that bracket! So nice!
    4x4Taco09[QUOTED] likes this.
  18. Oct 18, 2017 at 4:23 PM
    #38
    4x4Taco09
    Dane
    Louisiana
    The rack, bracket, and light bar will be for sale soon ;)
    Waiting for my Prinsu now
  19. Oct 23, 2017 at 12:21 AM
    #39
    tacos_modern_life
    Brandon
    Portland, OR
    What kind of bar do you have?
  20. Oct 23, 2017 at 2:52 AM
    #40
    4x4Taco09
    Dane
    Louisiana
    I bought it from a guy who did a group buy on here a few years back. 5 watt LEDs, spot pattern, 42.5". Ill go through my old PMs and see if he is still active on here
