Rigid Lights?
Discussion in 'General Automotive' started by gt40, Dec 9, 2012.
  1. Dec 9, 2012 at 10:22 AM
    gt40
    gt40 [OP] Well-Known Member
    Georgia
    11 SR5 4X4 SB TOW PKG.
    I've been looking at the Rigid Dually D2 Clear Driving Light - Set of Two - rig50231 and was wondering if I could wire them to the two round lights on the left & right sides of the lower bumper. ( FOG LIGHTS ).
    This way I could turn all 4 of them on and off with the push button switch on the left side of the dash. I would also get the "BLACKOUT" covers for the D2s when I only want the two round lights.
    Has anyone tried this and if you have how do you like it?
    I will mount them on the two tabs Avid welded to the back side of their LIGHT BAR.
  2. Dec 10, 2012 at 2:28 PM
    gt40
    Georgia
    Is my idea a bad one? I'm not getting any feed back. :confused:
  3. Dec 10, 2012 at 2:39 PM
    Kaboom90
    Kaboom90 Well-Known Member
    Austin
    Alabama
    2017 TRD OR 4X4
    Stock-ish
    When you say round lights I'm going to assume you mean your fog lights. Im not sure if you can run them through your fogs. If they are wired into your fogs then you'll be driving around with you rigids on at night which could get you lots of middle fingers. You should probably just run them separately. With a sr5 you should have plenty of blank switches where you could throw in a rocker switch to run your lights.
  4. Dec 15, 2012 at 6:46 AM
    boss1041
    boss1041 Well-Known Member
    chad
    valdosta, georgia
    07 dc 6 speed trd or, 95 auto
    I think it can be done but you would want to use a relay I believe. U may also wanna look into the fog light anytime mod for complete control over the lights. If it were me I would just put them on their own switch.
    P.s. try posting this topic in the lighting section for more replys.
  5. Dec 16, 2012 at 8:46 AM
    gt40
    Georgia
    Thanks to everyone. I think I will connect them to their own switch and be done with it. :D
  6. Dec 23, 2012 at 8:29 PM
    gt40
    Georgia
    Now I am ready to order a pair of Rigid D2s, but which ones?
    QUOTE:
    "The Rigid Industries D2 lights are available in a Dual Beam output that projects both a 9 degree spot and an 18 degree flood pattern . This gives your light optimum distance with good horizontal spread or a 30 Degree Wide Pattern designed to saturate your surroundings with High intensity LED Light."
    Could the guys that have these let me know which ones you would suggest. Should I get the 9 degree & 18 degree or the 30 degree wide pattern? :confused: :)
  7. Dec 23, 2012 at 8:30 PM
    motoxer311
    motoxer311 Well-Known Member
    I'm a Rigid dealer if anyone wants some prices. .
  8. Dec 24, 2012 at 11:33 AM
    gt40
    Georgia
