RIMS HELP ME OUT
Discussion in '4 Cylinder' started by Poe, Mar 7, 2014.
  1. Mar 7, 2014 at 10:12 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    I just got some cooper st maxxs 265/75/16 and haven't put them on yet.. i would like to get some rims first. but i don't understand any of the backspacing or offset, so can you guys help me choice the right rim. Can i get a rim that will make my tires stick out a little further? or should i just get tire spacers. Thanks guys!!
    Note: I would like some black rims i like the addict by KC
  2. Mar 7, 2014 at 10:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    5 lugger?
    You have a 4x4, no?
    16x8, 4.5" backspacing
  3. Mar 7, 2014 at 10:34 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    im stupid :(
  4. Mar 7, 2014 at 10:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    So you have a 4x4 or a 5-lug?
    If you have a 5-lug and you don't have a medium-travel or long-travel kit, you aren't going to fit those tires under the fenders.
  5. Mar 7, 2014 at 10:42 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    6 lugs, i messed up. 4x4
  6. Mar 7, 2014 at 10:51 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    do you know what the bolt pattern is?
  7. Mar 7, 2014 at 11:09 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
  8. Mar 7, 2014 at 11:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    6 x 5.5
    or metric, 6 x 139.7mm
    And if 4wheelparts doesn't have them in stock, it'll take you months to get them, if you ever get them.
    Those SHOULD work, but there are issues with the center bore diameter, and whether the wheels are hub-centric or lug-centric.
    You want them to be hub-centric, and sometimes that takes adapter rings. Lug-centric wheels tend to not balance out properly on the Tacoma.
