rims out-of-round/tire wear?
Discussion in 'Wheels & Tires' started by 04asphalt, Dec 22, 2007.
  1. Dec 22, 2007 at 11:10 AM
    04asphalt
    04asphalt [OP] Well-Known Member
    PreRunner
    trd prerunner has the alloy rims i believe...
    went to rotate/balance and the tech. told/showed me the passenger front that was going to the rear was out of round & tire is wearing uneven.
    only 10,000 miles on the truck so it should be a warranty issue right?
    others have this same problem?:confused:
  2. Dec 22, 2007 at 3:19 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Should be, hit anything lately ? let anybody drive you truck ? :eek:
  3. Dec 22, 2007 at 3:32 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    definately take it back to the dealer
  4. Dec 22, 2007 at 3:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    depending on the tire itself, that may be all it is....an out of round tire, may not be the rim at all. did the tech show you or prove to you that the rim was " bent" for it to be out of round along with the tire. reason i say this is because the bfg rugged trails that came stock on my prerunner, right around 10k miles, wouldnt balance because they were way outta round, rims were ok though. just a thought.
  5. Dec 22, 2007 at 4:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    An out-of-round wheel will most likely cause vibrations......
    What type of tire wear are you getting?
    Is it cupping? Is it in the center? On the outside? Inside?
  6. Dec 25, 2007 at 8:01 AM
    04asphalt
    PreRunner
    did they give you different tires? stuck a little nub thing to the inside rim while it was on the machine but I couldn't see anything:confused:
    could see the tread of the tire was way out of round:mad:
  7. Dec 25, 2007 at 7:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah...i just ran those tires till they were done...which was right around 23k miles....then i got new shoes. some tires just get outta round easy as hell. you may want to try balancing the tires and see if it helps....maybe try to get them "roadforce" balanced, which may help your case.
