Ringing noise from engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 86ceeten, Mar 2, 2010.
  1. May 4, 2010 at 6:29 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Maybe you just need to answer the phone. :anonymous:
    All kidding aside, I would like to hear what they find. Also as asked previously, can you record the sound and post it so we can hear it too for reference?
  2. May 5, 2010 at 2:10 AM
    86ceeten
    86ceeten [OP] Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Never got it fixed. The dealer has no idea what it is. The best they could come up with was to rum premium, and that made mo difference. I guess when it grenades I'll know then:)
  3. May 5, 2010 at 2:11 AM
    86ceeten
    Brian
    NW Florida
  4. May 13, 2017 at 6:40 PM
    rw4636
    rw4636 New Member
    Robert
    2009 Tacoma
    I know this is an old post... but it sounds like what I started hearing about a week back.
    When cold and under acceleration I can hear some engine noise best described as a jingle bell. Not an engine ping or valve lifter noise. I have had both in the past on other vehicles. I do not know if it could be piston slap.
    After the car warms up (like 15 miles) the noise gets quieter and almost goes away. I took it to my trusy mechanic, but it was too warmed up at that point and they could not hear it. Will take it back nest week. They thought it might be a idler pulley bearing going bad but could not explain why it would quiet down.
    It started right after changing the serpentine belt. I was very careful to not move the CS pully while RR'ing the belt.... could I have messed up the timing??
    This thread sounds so much like the noise I am hearing, any solutions?
    Thanks so much.
    vehicle description::
    2009 tacoma
    125K miles
    no engine mods done
    serpentine belt replaced just before noise started.
  5. Aug 6, 2019 at 12:41 PM
    skibum185
    skibum185 Active Member
    Big Sky, MT
    09 DCSB TRD
    Toytec Boss 3" lift URD Short Throw Magnaflow dumped 285/75/16 Duratracs SOS sliders Ext brake lines NWTI Bumpers VHF/UHF/CB Shackle flip
    Bueller? Similar things happening here
    BassAckwards likes this.
  6. Aug 6, 2019 at 12:56 PM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    subd. wonder if it ever grenade'd?
  7. Aug 6, 2019 at 1:27 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Does anyone know what model years have had this problem?
  8. Aug 6, 2019 at 1:36 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subadubdub
  9. Aug 6, 2019 at 1:39 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    someone needs to pinpoint the issue rather than say 'mysterious noise' and random 'I hear something'
    or we can say all model years have all sorts of noises. did it blow up yet ?
  10. Feb 8, 2020 at 8:07 PM
    Lazy Taco
    Lazy Taco Well-Known Member
    South Florida
    1996 2.4 Xtra Cab
    BONE STOCK
    Hey guys, my 1996 2.4 2 lug just started this yesterday @2000-2300 RPMS ONLY IN THIS RANGE , under load and in neutral , 156k miles .
    12k mi NGK iridium spark plugs,
    High octane gas used for span of week no relief.
    Car has a silent idle and not ringing in any other range no matter how much throttle input or thrash.
  11. Feb 8, 2020 at 10:44 PM
    skibum185
    Big Sky, MT
    09 DCSB TRD
    Glad to hear others still have this problem... it’s getting annoying at this point.. 6 months later and been chasing it non stop. Not heat shields, changed sparks a couple different times with high octane after to no avail. No noticeable exhaust or vacuum leak.. current theory is a bad cat that’s not throwing a code yet but slowly deteriorating. Tapping them with a mallet isn’t coming back useful and sounds intact. Mechanics are equal annoyed as they hear it back can’t track it. Tempted to find someone with a bore cam to jam all the way up into the cats if that’s even possible.
