RIPP Coil Packs
Discussion in 'Performance and Tuning' started by Beethoven22, Jun 26, 2020.
  1. Sep 1, 2021 at 8:59 PM
    #61
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    it had nothing to do with the hole. The RIPP pack is much larger then stock and when put into position and you line up the holes the top of the pack rubbed on the valve cover and would not let the coil pack sit flush. the pack itself is much larger then the stock one. The post linked before was my truck: https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-1643#post-24641456
    Even forcing it was just not there. Sure it would have worked but it should fit better.
    VE7OSR[QUOTED] likes this.
  2. Sep 1, 2021 at 9:44 PM
    #62
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    If i look at your pictures, and envision the mounting hole closer to the centerline of the pack versus offset, (more like the OEM) then rubbing on the valve cover would appear to not be an issue.
    EDIT i'll take this back, in that the RIPP packs for the 2.7L do show the mounting hole offset the same as shown in your pictures. I was wrong, the RIPP coil packs for the 2.7L are the same as the RIPP 4.0L model.
    https://www.rippmods.com/collection...ta-tacoma-2-0l-i4-high-performance-coil-packs
  3. Sep 2, 2021 at 12:47 AM
    #63
    nudavinci64
    Robert
    Yah In the current form they hit the valve cover which appears to not be an issue with the 2.7. But agree if the mounting point was moved over we would be in business.
  4. Sep 2, 2021 at 1:08 AM
    #64
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This regards the 4Runner/FJ version RIPP coils. The ones I currently run right now. Heres the story with them:
    The bolt mounting holes allow the coil to sit on the valve cover in an incorrect orientation in comparison to the OE one. Because of this it requires messing with the wiring harness particularly on Cyl. 2 which was beneath the supercharger or intake manifold.
    The secondary issue is the coil boots are too large. This is alleviated by making precise clean cuts with a razor blade of the boots to allow for proper fitment.
    One more size effect issue is that because the coils are so large, the OE bolts are subsequently a hair short and causes some issues when tightening them down since the coils sit a hair high despite the fact whether you cut the boots down or not. They just have a bit of upwards excessive pressure making for a semi uncomfortable to install and thread in those bolts properly. Particularly cyl #6.
    Multi issue problem that is easily remedied, but you better damn be sure of what you are doing before you get into it otherwise you just trashed a set of $300 coils.
  5. Sep 2, 2021 at 1:13 AM
    #65
    nudavinci64
    Robert
    Indeed. Hence why many opted for the Tacoma version which was a bust. =( Curious about the Sultan of Spark coils and how they compare to RIPP packs.
  6. Sep 2, 2021 at 1:18 AM
    #66
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Spark coils? Never heard of them.
    For the RIPPs, there are just a lot of risks that you need to take if you want to run them. I think any mod you want to do is worth the risk, but at the end of the day that's always your call on what you decide to do (I mean in general, not just you) lol.
  7. Sep 2, 2021 at 1:22 AM
    #67
    nudavinci64
    Robert
    SUMOTNK and VE7OSR like this.
  8. Oct 10, 2021 at 1:40 PM
    #68
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  9. Oct 10, 2021 at 2:26 PM
    #69
    nudavinci64
    Robert
    SUMOTNK[QUOTED] likes this.
  10. Oct 10, 2021 at 7:49 PM
    #70
    SUMOTNK
    Eddie
  11. Feb 14, 2022 at 9:17 AM
    #71
    SUMOTNK
    Eddie
    TaylorTRD, Chris(NJ) and Torspd like this.
  12. Feb 16, 2022 at 5:28 AM
    #72
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  13. Feb 16, 2022 at 12:39 PM
    #73
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
  14. Feb 16, 2022 at 5:01 PM
    #74
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Their site has tacoma results. 10-15hp for a 2gen, 20-30 for 3gen. iirc.
    But again, I'd trust tw member results more than the youtube tester's results or their own.
  15. Feb 17, 2022 at 2:52 AM
    #75
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I know, but they have no video of a 2nd gen 4.0L tacoma on the dyno. So I wanted to know how they got 10-15hp numbers. They gave me a video of a 4runner but they are dual vvti and are 270hp vs tacomas 236.
  16. Feb 17, 2022 at 4:57 AM
    #76
    Chris(NJ)
    08 Indigo 4x4 DC OR
    ah, I gotcha. They're more than welcome to put mine of the dyno. I'm only 25 mins from them. I'll buy them if they fit well and the results hold true
  17. Feb 17, 2022 at 5:14 AM
    #77
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    They emailed me and confirmed they have not dyno'd a 2nd gen tacoma with 4.0L. So take those 10-15hp gains for what it is but they have no evidence it actually will make that much more.
    Chris(NJ) likes this.
  18. Feb 17, 2022 at 11:13 AM
    #78
    vegasstaco
    vegasstaco Well-Known Member
    Jose
    N,W Houston
    4x4 TRD Sport
    Many
    Call them and let them know and please post the results here of (pre and post) coil packs we are all waiting!!!
    Chris(NJ)[QUOTED] likes this.
  19. Feb 17, 2022 at 11:24 AM
    #79
    Chris(NJ)
    08 Indigo 4x4 DC OR
    I'll reach out and see if they want to put it on the dyno.
    I sent them a message. We'll see what they say.
    BassAckwards likes this.
  20. Aug 3, 2022 at 6:55 AM
    #80
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Anyone running these on the 3rd gen and have positive things to say? My spark plugs are about to be due so I'm thinking of throwing these on while I do them
