Risks of "do it yourself" on upgrading your suspension
Discussion in 'Suspension' started by avengedkevinfold, Jan 24, 2011.
  1. Jan 24, 2011 at 7:49 AM
    avengedkevinfold
    avengedkevinfold [OP] Well-Known Member
    Kevin
    Socal - OC - Huntington Beach
    bilstien 5100s all the way around, ICON progressive 3 leaf kit, Illegal tint, snuglid SL, seatbelt chime mod. light racing UCAs
    I know very little about cars but I'm considering installing my new bilstien 5100s all the way around the truck and a new ICON leaf pack.
    I've got jack stands and jacks and all the tools needed to perform the install including the torque wrench.
    In regards to removing the coil over using a spring compressor and putting in the 5100 back into the coilover.... I'll be taking the assembly to a shop to have done because I understand this can be a dangerous job.
    I'll be using the following links for help. AAL Install
    Factory Torque Specs
    After the install I'll be taking the truck to get aligned and get new tires and wheels.
    With all of that being said, what are some of the risks involved in doing this myself? What are some of the common mistakes that could make this install go wrong or lead to suspension failures down the road?
    Am I missing anything in regards to instructions and/or tools to get the job done right?
    Is this a no brainer job or am I in over my head?
    Any other advice?
    Mac4Willy likes this.
  2. Jan 24, 2011 at 8:02 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    It looks like you have it all, just remember to take your time and double check everything when you re assemble it all. taking it all apart should be a breeze with any type of diagram and since your having the hardest parts done theres really no concern in just takin it all apart and putting it back together yourself, just double check! Good Luck
  3. Jan 24, 2011 at 8:22 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    You are already on the good path having given thought to the job as you have-hell in my younger days they sold frikkin coil spacers in the form of plastic slipins all the way to metal ones you can torque on with a wrench to achieve more height> Can you imagine what these did to a spring-changing the whole load bearing dynamics, putting extreme pressure on only one point of the coil etc.
    Compare that to how you're handling yours and you'll see you're doing fine:)
  4. Jan 24, 2011 at 8:40 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    I did my rear suspension yesterday. It took about 11 hours but one bolt took 2 and a half hours to get off. Make sure you have an impact wrench it makes everything way easier. I replaced my leafs and shocks and it wasn't hard just time consuming.
  5. Jan 24, 2011 at 8:44 AM
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Make sure you check all the bolts a couple times especially after a good shake down off roading, I hear the nuts on the u bolts tend to come loose and a leaf could shift
  6. Jan 24, 2011 at 8:56 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Changing out the coil over's isin't bad, just need to use good judgement and a good coil compressor and follow it's directions usually on the package. lots of do's and don't online to get that part safetly done.
    The compressor I used: http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=1KCEGNK70158E54HCCD0
    Don't tear boths sides down together, do one side then the other, that way you have a example to go back to.
  7. May 3, 2017 at 5:01 AM
    mikelcurtis
    mikelcurtis Member
    Taco
    It sounds like you have the tooling, and mindset to do a good job, you'll be fine. One of the most satisfying things we off roaders do is the 1st successful suspension rebuild.
    One piece of advice, give yourself plenty of time. If this truck is your daily driver, don't start on Sunday what you have to drive to work on Monday morning. Time compression makes for rushing and missing things.
    Above all, have fun!
    ChadsPride likes this.
  8. May 3, 2017 at 5:06 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    OP
    I agree with what has been said here. Sure there are risks, but it sounds like you have a good head on your shoulders.
    My advice would be to listen to that inside voice you have. If you get so far and decide (oh wait a second) then step back and wait.
    I'd be willing to bet that there are plenty of members in your area though. I'd find your local threads here and offer up a MOD day. The guys around here are often really accommodating when it comes to pitching in and helping out. You can make some good relationships too, and there is always a truck around to fetch that missing bolt that didn't come with your parts, or bounced into the sewer drain.
    Good luck!
  9. May 3, 2017 at 5:10 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I can't imagine he is still working on installing his suspension, seeing as he started this thread over 6 years ago.
  10. May 3, 2017 at 5:11 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Y'all realize this thread is 6 years old right?
  11. May 3, 2017 at 5:12 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  12. May 3, 2017 at 5:19 AM
    KiteGuam
    KiteGuam The favorite!
    Guam
    03 Xtra-Cab 2.7L 4X4
    starting over from scratch
    :smash:
  13. May 3, 2017 at 5:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Holy Zombie thread revival @mikelcurtis !
    Not only is the thread 6, the OP hasn't been around since January............ :D
  14. May 3, 2017 at 6:48 AM
    CR, WA
    stock
    He's almost got the last bolt in,,no one talk, he needs to concentrate. It's been a long 6 years and he wants to do this right. lol.
    KiteGuam, scottalot and DustStorm4x4 like this.
  15. May 3, 2017 at 7:26 AM
    urchim
    urchim Well-Known Member
    Tacoma 2016 TRD Offroad Inferno
    Links dont work, can you fix it.
    scottalot likes this.
  16. May 3, 2017 at 7:54 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Nope!
  17. May 3, 2017 at 7:57 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    OMG!!
    Well ,it was the thought that counts! Right? @mikelcurtis ?
    Thanks for pointing this out, I woulda been pissed if OP didn't write back on how it went.
  18. May 3, 2017 at 7:59 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  19. May 3, 2017 at 8:01 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Serves me right for looking at this during work.
    :smack:
  20. May 3, 2017 at 8:18 AM
    40950
    CR, WA
    stock
    lol. We have all done this. No one is immune. No biggie,,just funny.
    DustStorm4x4 and scottalot like this.
