rock lights question
Discussion in 'Lighting' started by irANTHONY, Apr 16, 2019.
  1. Apr 16, 2019 at 10:59 PM
    irANTHONY
    irANTHONY [OP] Well-Known Member
    hey guys! so i bought 2x 4 pack of rock lights
    (https://www.amazon.com/Offroad-Unde...s=rock+lights&qid=1555472004&s=gateway&sr=8-4)
    then i bought two wire harnesses that have 4 leads each
    ( https://www.amazon.com/Ampper-Light...1JCGWGP6BFY&psc=1&refRID=Z1SNZAH921JCGWGP6BFY )
    my question... if i wanted to control all of these lights with one switch... can i just combine both harnesses to share one switch? also could i add more wire to any of the harnesses for more lights?
    thanks guys!
    LP808 likes this.
  2. Apr 16, 2019 at 11:16 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Combined, you should be under the 40A allowed by the wiring harness. Therefor, you should be fine combining the two sets of rock lights. Check the amperage of the lights to ensure each set is less that 20A.
    irANTHONY [OP] likes this.
  3. Apr 16, 2019 at 11:32 PM
    irANTHONY
    each light is 9 watts so it would be a total of 72W and the harness says " The lights hooked up to this harness should be less than 150 W (totally) at the same time" so i should just add additional wires to just 1 harness? rather then to use two harnesses sharing the same switch?
  4. Apr 16, 2019 at 11:40 PM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Amperage on leds are pretty low. I am sure you would be fine.
  5. Apr 19, 2019 at 10:33 PM
    LP808
    LP808 Well-Known Member
    2016 Base SR5 Tacoma
    None
    I think it depends on the type of control. If it's Bluetooth and they're both of the same brand, I think it's possible to combine the two sets
  6. Apr 19, 2019 at 10:35 PM
    LP808
    None
    Anyone running an 8 pod system on their 3rd gen Tacomas? Where did you place them(aside from the fenderwell)?
