Rockymounts Driveshaft SD or Dakine Pick-up Pad
Discussion in 'Sports, Hobbies & Interests' started by brizower, Jul 30, 2013.
Which would you recommend?
Poll closed Aug 29, 2013.
  1. Dakine Pick-up Pad
    0 vote(s)
    0.0%
  2. Rockymounts Driveshaft HD
    0 vote(s)
    0.0%
  1. Jul 30, 2013 at 12:59 AM
    brizower
    brizower [OP] Well-Known Member
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    So which would you recommend?
    From what I can tell-
    Dakine Pick-up Pad:
    Pros
    Room for a lot of bikes (5)
    Less time to throw my bike in the truck
    Cons
    No locks whatsoever for the pad or the bikes (wouldn't be hard to run a chain through the frame though)
    Could scratch the paint on my tailgate if left on too long?
    Should be removed installed with each use
    Driveshaft SD:
    Pros
    Semi-permanently installed
    15/20mm thruaxles can be locked
    Able to secure 9mm QR and 15/20mm thruaxles (good for my Heckler, or mine and my wife's hardtails)
    Cons
    Takes a little more time to put the bikes in the truck
    $80 each
    Have to remove the front wheel and most likely store inside the truck
    9mm QR bikes can not be locked
