Rolled my Tacoma is it worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SkeetFighter, Nov 20, 2023.
  1. Nov 20, 2023 at 12:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Remount the tire and it's safe to drive as-is.
    Fender is a bolt-on replacement. You can buy it pre-painted on some sites like Partify. For the rest, go get a quote from a PDR technician. Dents in the cab and bed side should be able to be popped out without much trouble by PDR technician. He may refuse to work on the door if there are bonded steel beams inside.
  2. Nov 20, 2023 at 2:01 PM
    tanstaafl26
    tanstaafl26 Well-Known Member
    San Diego
    Tacoma TRD 4x4
    Deal with the fluids, fill the tires, pull/bang out the dents so the door operates and drive it.
  3. Nov 20, 2023 at 2:31 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    it's a keeper ! like others have said , pull plugs , drain fluids , check for leaks and ifn she cranks keep on keeping on . do the body repair at your leisure .
    cruxofthebisquit and Green1GT like this.
  4. Nov 20, 2023 at 2:39 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah....you know....chicks dig scars....
    Green1GT, Kevins60 and rocknbil like this.
  5. Nov 20, 2023 at 2:51 PM
    9kfever
    9kfever Well-Known Member
    Sorry to see!
  6. Nov 20, 2023 at 2:54 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If the frame is okay and the A pillars and roof aren't damaged I'd say keep it and fix it.
    cruxofthebisquit likes this.
  7. Nov 20, 2023 at 2:55 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    shit.. that thing would look mint again with a days worth of work... keep er on the road
    Green1GT likes this.
  8. Nov 20, 2023 at 2:58 PM
    stevesnj
    rocknbil likes this.
  9. Nov 20, 2023 at 4:31 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
  10. Nov 20, 2023 at 4:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'd keep driving it.
    FWIW I almost did the same thing about a week ago. Was driving on a narrow, curvy rural road near home. It had rained the night before, but this was about 4 PM. The road was slightly wet. I approached a S curve and coasted through at about 20 mph. As I came out of the last curve I gave it a little gas and the rear end immediately fishtailed and got me sideways in the road.
    I tried steering into the skid, but it didn't help. I ended up spinning 180 degrees and off the road. Fortunately, I hit a spot with no real ditch, just a slight dirt bank. I got out and couldn't find any damage. Drove down the road a short distance where I could turn around and continued on my way. Was only a couple of miles from home.
    My TPMS light did come on and when I got home, I found the right rear tire only had 10 PSI. I aired up and it is still holding air 10 days later. I suspect the bead came off temporarily when that tire slid into the bank and then resealed.
    I was luckier than you. Sometimes it doesn't take much on wet pavement and off road tires aren't the best on wet pavement.
  11. Nov 20, 2023 at 5:37 PM
    O'Silver_Taco
    MD
    Most dangerous animal in the world.......
    ......a 17yr old with a pickup.....
  12. Nov 21, 2023 at 5:29 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    fix it and drive it. I wish that I had a photo of my 74 Ford F100. The only part of the truck not dented was the drivers side front fender. The truck looked like shit. but I did a very cheap overhaul, new pistons and rings, re honed the cylinders and had the head rebuilt. It ran like a scalded dog for a 300 straight six with big 1 barrel carb. You could try deflating a football or basketball to pop the dents out of the rear of the cab.
  13. Nov 21, 2023 at 7:43 PM
    L78
    L78 Well-Known Member
    Tony
    Nor Cal
    1995 Tacoma DLX, 2.7/Manual, 4x4, 1 family ownership
    Mostly stock, added custom wood bed rails and a Sony/Infinity stereo system
    Check the grass coming out of the bead on the front wheel...
    I'd get those two wheels/tires remounted and balanced. I'd worry about a bent axle flange, but otherwise, drive on!
  14. Nov 21, 2023 at 9:11 PM
    O'Silver_Taco
    MD
    Its looks to me like the driver rear wheel is damaged, or maybe the hub.
  15. Nov 21, 2023 at 9:20 PM
    #35
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Bummer on the Insurance. Glad you walked away
