Rolled truck getting a new cab!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Truckdriver, Dec 17, 2014.
  1. Dec 17, 2014 at 5:17 PM
    Truckdriver
    Truckdriver [OP] Member
    Oregon
    2000 tacoma 4wd auto
    Hellow all, I'm new here so greetings! I am hoping to find some helpfull information about swapping a 1998 2.4 2wd excab cab onto a rolled 2000 4wd 2.7 excab I have r n rd quite a few engines and trans etc so I know my way around a toolbox ,I am wondering what some specific tips might be .any help would be greatly appreciated.
  2. Dec 17, 2014 at 5:20 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    A few friends and some rounds of beer.
  3. Dec 17, 2014 at 10:55 PM
    Truckdriver
    Oregon
    Has anyone here done the swap or a similar swap with first gen rigs?
  4. Dec 18, 2014 at 8:15 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I've never heard of it done but I don't think they are all that different.
  5. Dec 18, 2014 at 8:18 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
  6. Dec 18, 2014 at 9:26 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I've done several cab swaps. The only issue you will have is you'll need to cut the holes for the shifters, not a big deal. Everything else swaps over easily. The cab is easier to move with everything out, interior wiring etc. You should be able to leave your heater boxes in place on the donor cab. Good Luck.
  7. Dec 19, 2014 at 7:51 AM
    Truckdriver
    Oregon
    all the wiring has to be swapped? i was hoping that i could get away with a main harness connector and computer situation :(
  8. Dec 19, 2014 at 11:08 AM
    markmb45
    Mark
    Utah
    Its not as bad as it sounds. Once the dash is removed the main harness is right there, then its a matter of disconnecting the different components, and seperating the sub harnesses. Then swapping the harness to the new cab. The differences between a 2wd harness and 4wd harness are numerous e-locker, transfer case, cruise, etc. Also beware toyota has a tendancy to change wire connectors between model years It would be a nightmare to wire it up to work with your 4wd components. Swapping the harness will only take a couple of hours, and easier in the long run. PM me if you need more info.
  9. Dec 23, 2014 at 1:44 PM
    Truckdriver
    Oregon
    Thanks I probably will need to do that .It seems doable though however the 5lugger is my driver at the moment so Im looking at other locale options for a cab .
  10. Dec 23, 2014 at 1:46 PM
    Truckdriver
    Oregon
    Thanks for those links reading those gave me confidence .I let out a hoot when I saw the pics of the new cab setting in place!
  11. Feb 8, 2015 at 8:37 PM
    Truckdriver
    Oregon
    well i picked up a cab from a 96 extra cab 4x4 in decent shape with both fenders and the half of the bed opposite my good half for 600 bucks :cool: almost complete interior too if anyone needs interior parts cheap I'm in southern oregon. I'm welding the two halves of bed together they are both white.
  12. Feb 8, 2015 at 8:45 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Truckdriver! Where in southern Oregon are ya!??
  13. Feb 8, 2015 at 9:16 PM
    Truckdriver
    Oregon
    she's a peach :)
  14. Feb 8, 2015 at 9:19 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Nothing quite like a Sierpinski triangle.
  15. Feb 8, 2015 at 9:30 PM
    Truckdriver
    Oregon
    williams
  16. Feb 8, 2015 at 9:35 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Is that a piece of the triforce you have attached?
    I have been looking forever for that damn thing
  17. Feb 8, 2015 at 9:41 PM
    Truckdriver
    Oregon
    well on her way!
  18. Feb 8, 2015 at 9:52 PM
    Truckdriver
    Oregon
    not sure just found it one day while looking at pictures on google.
  19. Feb 9, 2015 at 8:38 AM
    Truckdriver
    Oregon
    my sincere apologies for the subpar documentation thus far as i kept forgetting to bring the camera to where i performed the actual raising and lowering of the cabs .i used a ramsey winch and a snatch block with a large beam in a barn.
