Roof Antenna not connected from factory?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KnurledNut, May 29, 2010.
  1. May 29, 2010 at 2:17 PM
    KnurledNut
    KnurledNut [OP] Cracker in a Taco
    Sonova Beach
    '10 PreRunner SR5
    I'm having problems with using the 'shark fin' antenna on the roof. I have the adapter cable from Vais but I keep getting an antenna error. When I use the magnetic antenna from Sirius everything works. Is it possible the factory missed the connections during assembly? I also wonder if I can take my Taco in under warranty for this.
    Thanks.
  2. May 29, 2010 at 4:56 PM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
  3. May 29, 2010 at 5:00 PM
    Faskev
    Faskev Well-Known Member
    I am using the adapter from tss-radio.com and it works great. Your antenna may be defective.
  4. May 29, 2010 at 5:09 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    where are you connecting the Vais cable?
  5. May 29, 2010 at 9:56 PM
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Driver's side kick panel.
    I forgot to add this is the second adapter cable so I'm thinking the roof antenna is disconnected.
    Anyone ever take the headliner off?
  6. May 29, 2010 at 9:59 PM
    The_Hodge
    SC
    i would take it back to the dealership so that if anything get messed up in the process of the headliner removal, etc, it's on them. under warranty anyways.
  7. May 29, 2010 at 10:35 PM
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Thats what I'm thinking as well. The shark fin antenna is supposed to be pre-wired from the factory. All I'm doing is plugging into an existing connector.
    I have an email out to VAIS...I'll wait for them first.
  8. May 30, 2010 at 12:19 PM
    ChaseUA
    Chase
    Bama
    My only concern is that the dealership won't address the issue, as the VAIS "wiring" is not an OEM wire.
    Has anyone had any luck with the dealership trouble shooting the antennae when the receiver/wiring is not an OEM product?
  9. May 30, 2010 at 12:54 PM
    ctxtaco
    ctxtaco Well-Known Member
    Austin, Texas
    2010 PreRunner SR5 Double Cab
    Black tube steps
    I purchased a Vais cable and plugged it into the plug in the driver's kick panel. It worked like a champ when connected to my Roady II XM receiver.
  10. May 31, 2010 at 8:06 AM
    KnurledNut
    Sonova Beach
    '10 PreRunner SR5
    Nobody has had an issue except me, that's why I'm thinking they forgot to hook something up on the assembly line.
  11. Feb 22, 2015 at 1:02 PM
    GenPatton
    GenPatton Member
    Paratrooper
    Columbia SC
    2009 Tacoma 4x4 V6
    Where Would the antenna (for sat radio?) be plugged into? I do not have sat radio? in my 2009 Tacoma 4x4.
    Thanks
