Roof basket security
Discussion in '1st Gen. Tacomas (1995-2004)' started by smuook, Dec 10, 2009.
  1. Dec 10, 2009 at 10:40 AM
    smuook
    smuook [OP] Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    Installed a Rola roof basket today. Everything went well. I'm looking for suggestions on how to make the mounting more secure so someone would have a hard time trying to steal it. The hand nuts can be unscrewed in a few minutes and the whole thing can be easily removed. I have an SUV and I want to be able to swap the basket between the two trucks but I don't want it to be too easy. I was thinking about nylon locking nuts... but any suggestions or help would be appreciated. Thanks.
  2. Dec 10, 2009 at 10:45 AM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    if it bolts through the lid. use a flat top carriage bolt so you can only unbolt it from the inside.
    It's hard to say though, can't really see your whole set up. I'd like to see what other people come up with as well.
  3. Dec 10, 2009 at 10:49 AM
    smuook
    Frank
    Loganville, GA
    I wanted the bolts on the inside... but the way the mount is, it just didn't work. Here's what it looks like underneath:
  4. Dec 10, 2009 at 10:52 AM
    smuook
    Frank
    Loganville, GA
    I like the carriage bolt idea, it has potential. Any other ideas? Thanks again.
  5. Dec 10, 2009 at 10:57 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    tac weld, or some sort of lock through one of the screw nuts so you can't turn it.
  6. Dec 10, 2009 at 11:13 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I'd search for some sort of security fastener, something along this line and replace the thumb nuts
    You may need to install a washer of some sorts to seal against leaks
    http://www.brycefastener.com/pentanut.htm
  7. Dec 10, 2009 at 11:50 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Yep, +1
  8. Dec 10, 2009 at 11:58 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    thats a great idea i wish i thought about it:mad:
  9. Dec 10, 2009 at 12:35 PM
    smuook
    Frank
    Loganville, GA
    Thanks for the great suggestions. The pentanut looks pretty friggin cool... but knowing me I'd loose the socket. :p I think I'm gonna go with a carriage bolt type setup on top and a nylon locking nut inside. Somebody will have to work to get at it. That's enough to discourage most common thieves. I figure if they want it bad enough, they'll be able to get it no matter what I do. Thanks for the help. :)
  10. Dec 10, 2009 at 4:45 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    can we get a pic of the whole truck with the rack on
  11. Dec 10, 2009 at 4:56 PM
    smuook
    Frank
    Loganville, GA
    Sure... It's a pretty sturdy basket but the only thing I don't like about it is that it's two pieces that are fitted together then fastened with screws. It would be nicer if it came one piece.
  12. Dec 10, 2009 at 5:00 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    lift the truck higher so they need a ladder to reach lol
  13. Dec 10, 2009 at 5:01 PM
    matthew5olson
    matthew
    pittsburgh, PA
    ah. I thought it was on your roof.
  14. Dec 10, 2009 at 5:09 PM
    smuook
    Frank
    Loganville, GA
    Ha.... maybe someday. Only doing little bits at a time.
  15. Dec 10, 2009 at 5:11 PM
    smuook
    Frank
    Loganville, GA
    How do you like your grill? I'm thinking about doing that as well.
  16. Dec 10, 2009 at 5:37 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I like it on the 2nd gens much better. I have a grill guard over it now so its not sticking out the so much. I like it better than the stock the. I mostly like the change from chrome to metalic grey. (i painted it)
  17. Dec 10, 2009 at 6:01 PM
    smuook
    Frank
    Loganville, GA
    Cool, thanks. The vertical bars always seemed weird to me.
  18. Dec 11, 2009 at 5:32 AM
    Dabates
    Dabates Well-Known Member
    Guelph, Ontario
    2001 TRD
    Any wind noise from the rack when you drive?
    I'd love to do this to mine but I think it'd have to be a Thule setup because all of our attachments are Thule.
  19. Dec 11, 2009 at 5:40 AM
    matthew5olson
    matthew
    pittsburgh, PA
    vertical bars?
  20. Dec 11, 2009 at 1:33 PM
    smuook
    Frank
    Loganville, GA
    Sorry, yeah... the black grill bars that you removed for the mesh (the things you cut out)... the ones that make it look like a jeep. I'm probably not describing it very well.
