Roof Rack accessory mounts (transporting olympic bar)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taco2018x, Sep 27, 2020.
  1. Sep 27, 2020 at 8:26 PM
    taco2018x
    taco2018x [OP] Member
    2018 TRD OR
    I have a DCSB '18 Off Road with a camper. I'm getting a roof rack (attached to the main cab) so I can transport my Olympic barbell. I travel to my clients to train them and would like to mount the barbell on the outside instead of leaning it into the bed and strapping it down (bending the bar).
    I was wondering if anyone knows of a mount for Thule square bar so I can attached the barbell perpendicular (from front to back) to the crossbars?
    I need something like this but the top portion facing the other way.
    Smittybilt SRC Roof Rack Adapter Kit - DRS-6
    Thanks in advance.
    Taco-piper likes this.
  2. Sep 27, 2020 at 8:53 PM
    taco2018x
    2018 TRD OR
  3. Mar 12, 2021 at 12:10 PM
    Fortybelow
    Fortybelow Well-Known Member
  4. Mar 12, 2021 at 12:16 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Quickfist clamp mounts would probably work. Otheriwse just strap it tightly to the rack (take the plates off first ;)
  5. Feb 16, 2023 at 3:50 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Four quick fists, two in body two on collars. Get ready for a law suit if you ever get in an accident.
