roof rack with no drilling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Aug 15, 2010.
  1. Aug 15, 2010 at 7:37 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    i want a defender roof rack, is there any way to mount it using those gutters on the roof,under the rubber seal..i dont wanna drill in the roof...thank you:confused:
  2. Aug 16, 2010 at 2:32 AM
    Deuxdiesel
    Deuxdiesel Well-Known Member
    SE MI
    '12 Silver Streak stocker
    Those "gutters" are just wide enough to fit 1" wide box tubing, and if you can find some 1"x2" and cut some short sections (3 or 4" long), drill the correct holes in them and bolt them down, it should give you some solid footings to mount a rack. I fooled around with making a single long piece to do this, but gave up because of the compound curve it requires- tons of cutting and welding. Maybe when it cools down this fall I'll try again
  3. Aug 16, 2010 at 3:39 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    thule racks dont require drilling
  4. Aug 16, 2010 at 9:13 AM
    Deuxdiesel
    SE MI
    Neither do the Yakima's, but they won't hold as much as the defender will without damaging the roof.
  5. Aug 16, 2010 at 9:17 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    there are weld-nuts pre-installed in the rails under the weather stripping on the roof if you are a double cab. Find the correct threaded bolts and the weld-nuts, cut/drill holes into what ever rack you want to run, and bolt it down...no cutting watsoever on your roof
  6. Aug 16, 2010 at 9:19 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. I used to have the Yakima on mine but swapped it out for the OEM roof rack.
  7. Aug 16, 2010 at 12:48 PM
    kinkrider101
    santa barbara
    wheels and tires
    i want a defender so i can have lights in the front/rear...i just went camping and could have really used extra space
  8. Oct 8, 2010 at 6:33 PM
    kinkrider101
    santa barbara
    wheels and tires
    but would the roof rack be laying on top of the roof?:eek:
  9. Oct 9, 2010 at 5:14 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Get an OEM rack and put a basket on top. mount lights to the basket. I think that would look killer
  10. Oct 21, 2010 at 5:56 PM
    kinkrider101
    santa barbara
    wheels and tires
    Would the defender brackets happen to fit in the gutter
  11. Oct 21, 2010 at 6:10 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
  12. Oct 21, 2010 at 6:29 PM
    kinkrider101
    santa barbara
    wheels and tires
  13. Oct 21, 2010 at 10:40 PM
    kinkrider101
    santa barbara
    wheels and tires
