Rookie 33" and 35" Tire Question
Discussion in 'Wheels & Tires' started by tensecondchevelle, Jan 3, 2013.
  1. Jan 3, 2013 at 8:49 AM
    tensecondchevelle
    tensecondchevelle [OP] Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    I was talking to a guy at a tire shop a few days ago about lifting my Tacoma and getting larger wheels. He was saying that if I put 33's or 35's on my Tacoma it would accelerate very slow or "dog down" (as he put it) because my Tacoma is 6 Cylinder.
    Is this correct, or is he just being an old pessimistic man? I don’t put my foot on the floor all that often, but I do like the get up and go that the Tacoma has when I need it.
    I have a '06 Doublecab
  2. Jan 3, 2013 at 8:52 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Yep, the old man is right. Unless you re-gear to a lower ratio to compensate for the larger diameter tires, your Tacoma will be more sluggish.
  3. Jan 3, 2013 at 8:59 AM
    bzzr2
    bzzr2 Well-Known Member
    biggers tires will be more work to turn no matter what because of the larger circumference, but the weight of the tire will be another factor, if you are planning on running a heavy duty mud tire in a 35 that weighs in at 80lbs that's a lot of extra rotational mass to turn. if you are planning on running more of a street tire, that is a lighter load range and much lighter overall then this tire will turn easier than a heavy off road tire. tons of ppl run 33's and have not regeared and do not need to. i woudn't let one guy change your mind just because he thinks your truck will be to slow. you will still have more get up and go then ppl running the 4cyl!
  4. Jan 3, 2013 at 9:00 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    35's for 60k miles here. Not slow at all. Not what it was stock but the truck still runs just fine
  5. Jan 3, 2013 at 9:04 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    x2 for this. You will notice a small difference on 33's. 35's I would definitely re gear for mileage sake. Then you need to think about what type of driving you will be doing. More street driving I would say just use a 33 or even a 32. Then the re gear isn't really necessary. If you plan on doing a lot of wheeling then a re gear may be in your future with 33's and def 35's. Tire weight will play a big factor in it as well. Hope all the replys help ya out.
  6. Jan 3, 2013 at 9:04 AM
    MYT4CO
    MYT4CO Well-Known Member
    mark
    TX
    MYT4CO
    2012 taco, 92 toyota pickup, 95 4runner
    you havent regeared?
  7. Jan 3, 2013 at 9:22 AM
    PLC721
    Patrick
    Chandler, Az
    Nope
  8. Jan 3, 2013 at 9:27 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    You should. 4.88s. I think youd fall way in love.
  9. Jan 3, 2013 at 9:31 AM
    MYT4CO
    mark
    TX
    MYT4CO
    yeah i got 4.56's and think 4.88's would b a lil better
  10. Jan 3, 2013 at 9:33 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I noticed a huge difference going from 31s straight to 35s. Extremely sluggish especially in the high gears. I can't be in 6th gear on the highway doing 75 I have to be in 5th to maintain speed. Definitely regear if you are going for 35s.
  11. Jan 3, 2013 at 9:34 AM
    PLC721
    Patrick
    Chandler, Az
    hmmm..i was thinking in the 4.30 range since its my DD and i do go on the highway for trips and stuff?
  12. Jan 3, 2013 at 9:43 AM
    MYT4CO
    mark
    TX
    MYT4CO
    456's are good on the highway
  13. Jan 3, 2013 at 9:44 AM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    I don't know of any 4.30 gears for our front diffs... I love my 4.88's for my 33's. Would be overkill for the manual tranny though. Basically every thread I have seen on this ends with, 4.88's for the auto tranny and 4.56's for the manual tranny. 4.10's and 3.90's aren't worth the cost of a regear and there are no other options for our front diffs. Check out eastcoastgearsupply.com, they can send you pre-assembled diffs that are pretty easy to swap yourself.
    I am running 55lb 255/85/16 KM2's (33x10) and it was a little sluggish on stock gears. Would rarely run in Overdrive at 75 unless I was going downhill. With the 4.88's it takes a pretty steep hill to make it shift down and I lost less than 1 mpg with the higher rpm.
  14. Jan 3, 2013 at 9:54 AM
    jandrews
    4.56 puts you at stock-like gearing with 35s. I run 4.56 with 33s, slight overgear, and I wish Toyota had done it this way from factory. Truck has so much more balls now.
    Advice for you: give up on gas mileage. Lift, armor, larger tires etc a slight undergear wont do a damn thing for MPG but leave the truck sluggish. Go to 4.88s and your MPG will still be bad but at least your truck will shit n get when you want it to.
    The advantage offroad is also phenomenal.
  15. Jan 3, 2013 at 9:56 AM
    DevL
    DevL Well-Known Member
    If you want close to stock gearing and maximal fuel efficiency you want 4.10 for 33" and 4.56 for 35" tires. There are no 4.27 for our truck.
  16. Jan 3, 2013 at 11:08 AM
    tensecondchevelle
    Eric
    Mesa Arizona
    Shoot. This whole re gearing thing that everyone is talking about means I'm going to be spending a lot more time on this website in the coming days trying to figure it all out. haha
    So if I plan on just doing a lift (I'm still trying to figure out how high) and I'm mostly just going to be driving in the city 33's would be recommended? With the 33's I wont notice a whole lot of power loss I would assume?
  17. Jan 3, 2013 at 11:20 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I'm running 33.3" tires on my 4Banger with stock gears.
    Did I loose a little get up & go? Yes.
    Will I regear? No.
  18. Jan 3, 2013 at 11:28 AM
    tensecondchevelle
    Eric
    Mesa Arizona
    Thanks Man!!!
  19. Jan 3, 2013 at 11:39 AM
    ross123
    ross123 Well-Known Member
    fort bragg
    I noticed a difference with 33's
  20. Jan 3, 2013 at 11:50 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    You need to consider more than just the circumference when calculating optimal gearing. While the gearing ratios for the 4.56 with 35's are close to stock, you really want to over gear to also make up for all the added un-sprung weight of the tires/wheels. 4.56 is perfect for the larger 33 and added weight. It would probably be slightly underpowered with 35's vs. stock gearing.
