Roostfactor’s Equal Length Y-Pipe
Discussion in 'Performance and Tuning' started by 5thGearPinned, Aug 7, 2018.
  1. Sep 2, 2018 at 11:59 AM
    #341
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    They hardly spoke English .. I basically tell them what I want. However, they did say “ muy bueno ! “
    @Roostfactor - Yup .. rasp is gone. I might hold off on adding the high flow cat. I’m digging how it sounds. It’s definitely a deeper tone but not too loud.
    I’m running a vibrant and a magna res before the muffler.
    Roostfactor likes this.
  2. Sep 2, 2018 at 2:48 PM
    #342
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @jojotoo
    AWESOME!!!
    I dont think the cat quiets it down much, it just for people with headers so we have a cat, not for sound control.
    I dont remember if you had headers or factory manifolds?
    Do you notice any power difference? Smoother? Less throttle cruising down the highway?
    The engine should just feel like it has an easier time breathing overall if that makes sense.
  3. Sep 2, 2018 at 4:58 PM
    #343
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Not to thread jack. But I just installed a urd Intake. And now when I let off gas in a high rpm with out shifting. It rumbles and grumbles and backfires on occasion. Sounds so nasty lol. Some might not like it. But race truck.
    TitanRattler813 and 12TRDTacoma like this.
  4. Sep 3, 2018 at 8:01 PM
    #344
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Yup .. running URD headers.
    I just got to Vegas from LA. It seems to accelerate quicker. Definitely feels smoother.
    The pipe was rubbing against cross member when it was all bolted down. I used some heat wrap where it was touching. It’s all good now ..
    Totally happy with it !
  5. Sep 3, 2018 at 8:43 PM
    #345
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Oddly enough, after 300 miles or so.. my cel still haven’t set. ¯\_(ツ)_/¯
    Stryker420 likes this.
  6. Sep 3, 2018 at 8:47 PM
    #346
    Roostfactor
    TX panhandle
    That's interesting. When we made @loginfailed s one of the pipes came close to the crossmember so we put a small dimple in it for clearance.
    Since then I am extra careful with ensuring there is adequate clearance there. At least an inch. I understand there will be a little bit of tolerence difference between each vehicle but that is quite a difference from mine.
    Do you have the l brackets installed that go from the trans to the lower header flange?
  7. Sep 3, 2018 at 8:51 PM
    #347
    jojotoo
    Brandon
    Socal
    2015 DCLB
    I had the same issue with the URD y pipe. Maybe an issue for the pre-runner vs 4x4 ? I dunno ..
  8. Sep 3, 2018 at 9:02 PM
    #348
    Roostfactor
    TX panhandle
    What's the code? It got a p0420 today as well. I just clear them now.
  9. Sep 3, 2018 at 9:03 PM
    #349
    Roostfactor
    TX panhandle
    Ahhh, you may have something there. Your crossmember may sit higher or further forward because no transfer case? If you get a chance send me a pic of where its rubbing please so I can try to determine where and why.
    Thanks for the updates and super happy your stoked with it!
    Roost
    Stryker420 and Torspd like this.
  10. Sep 3, 2018 at 9:08 PM
    #350
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Well, lol .. I was getting the p0430..but after ANOTHER session with Scott, I’m getting P013C. Can’t win .. it’s one or the other. Last session, he increased my injector size.
    Stryker420 and loginfailed like this.
  11. Sep 3, 2018 at 9:15 PM
    #351
    Roostfactor
    TX panhandle
    Are you running the 61lb injectors? Or factory sc injectors?
  12. Sep 3, 2018 at 9:18 PM
    #352
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    California carb legal. Lol
    12TRDTacoma likes this.
  13. Sep 3, 2018 at 9:26 PM
    #353
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Nope .. factory SC injectors. I have 80s on deck tho.
    My truck is running pretty good right now. With the added CSF radiator, plus your y pipe. All my temps looks good .. the truck runs smooth.
  14. Sep 3, 2018 at 11:35 PM
    #354
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    For P013C and/or P0430, try replacing the rear O2 sensor on the driver side.
    On these O2 sensor codes, I’ve learned not to immediately blame the UCON. I had a stubborn O2 code that wouldn’t go away. Since I replaced the related sensor my truck has been spitting unicorns and rainbows from the tail pipe.
  15. Sep 4, 2018 at 1:40 PM
    #355
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Or change the the timing on the camshafts like the new gt500 mustangs do. Also old Indy v8 cars did the same thing. We've dabled in it with some custom ground cams for SBC but haven't seen the gains we expected. This was on N/A circle track cars with all custom headers and exhaust. My thinking is we would of seen some gains on a SC or TC engine.
  16. Sep 4, 2018 at 4:04 PM
    #356
    Roostfactor
    TX panhandle
    Yes that's very advanced stuff changing the firing order on v8's to try to find an advantage with induction, cooling, and or exhaust. Tricky stuff for sure as you are changing the whole dynamic of the engine including potential harmonic vibrations, etc.
  17. Sep 7, 2018 at 1:41 AM
    #357
    TitanRattler813
    TitanRattler813 Active Member
    Sean
    Davie, FL
    2012 Nautical Blue X-Runner (Formerly 07 RR X-Runner)
    Just beginning...
    Please tell me I can get in on this @Roostfactor :bowdown:
    I really have to look outside of XR-U more often. @o0opackersfano0o has been holding out on us lol
  18. Sep 7, 2018 at 4:18 AM
    #358
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What's up Titan?! You'd be surprised at how much more performance oriented TW has become over the years. Incredibly.
    JWL, 12TRDTacoma, Roostfactor and 2 others like this.
  19. Sep 7, 2018 at 6:18 AM
    #359
    TitanRattler813
    Sean
    Davie, FL
    Just beginning...
    I'm just really getting back into it. I'm on X-Runner #2 and now that it's paid off and almost out of warranty, it's game-on. The X-Runner feels so slow compared to my Ecoboost MKS so I want to at least make it comparable since my wife permanently borrowed the MKS lol.
    Torspd[QUOTED] and Roostfactor like this.
  20. Sep 7, 2018 at 6:59 AM
    #360
    Roostfactor
    TX panhandle
    Hey Titan,
    I think we can work something out for you. If you have read through the thread you know these take time to build and I currently have 7 to make so it will be 30 to 60 days minimum before I get to yours.
    In my first post I explained pretty much everything so if you want one please pm me.
    Edit: I see your conversation and will reply to you there.
