Roostfactor’s Equal Length Y-Pipe
Discussion in 'Performance and Tuning' started by 5thGearPinned, Aug 7, 2018.
  1. Sep 17, 2018 at 6:48 PM
    #501
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Couldnt agree more! I was surprised how well he could break things down to where i could understand it all. Learned so much just shooting the shit with him
  2. Sep 17, 2018 at 7:04 PM
    #502
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @Roostfactor , I think you need to charge Dr Gas for the advertising.
  3. Sep 17, 2018 at 7:35 PM
    #503
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You said the URD y-pipe also rubbed in the same spot correct?
    If so that's interesting. I dont know if the pre-runners cross member sits higher or if you have a motor mount sagging or what.
    It will be interesting to see what clearance is like on the next pre runner.
  4. Sep 17, 2018 at 7:37 PM
    #504
    Roostfactor
    TX panhandle
    Thanks RJB!!! Yes it seems all my weekends have been long and busy lately.
    I do enjoy it though and like helping people and sharing knowledge.
    That's a sweet welding pic!
  5. Sep 17, 2018 at 7:38 PM
    #505
    Roostfactor
    TX panhandle
    Or get my own stickers made!
  6. Sep 17, 2018 at 7:38 PM
    #506
    Roostfactor
    TX panhandle
    Thank you guys for the complements!!!
  7. Sep 17, 2018 at 9:45 PM
    #507
    Droptopfox
    Droptopfox Works at Tinkers’ Nook
    Jermaine
    AZ
    2008 TRD Sport DCLB 4x4
    Do you have any video sound clips you can share? I really want to know how this sounds vs. the unequal length headers.
  8. Sep 18, 2018 at 12:57 PM
    #508
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Yup same spot.
    I think my cross member is a bit higher. I could be a one-off tho. Who knows ..
    Roostfactor[QUOTED] likes this.
  9. Sep 18, 2018 at 1:02 PM
    #509
    BassAckwards
    I will try to get some here in the next day or so.. My setup will vary a lot from other's with this y-pipe though as my exhaust is verryyy loud. I can't even hear the S/C whine anymore, which makes me sad, as I enjoyed that
    5thGearPinned[OP] likes this.
  10. Sep 18, 2018 at 1:11 PM
    #510
    Roostfactor
    TX panhandle
    I told you man. Imagine if I hadn't talked you into that Ultaquiet resonator. It would've been insanely loud.
  11. Sep 18, 2018 at 1:12 PM
    #511
    BassAckwards
    You werent joking! Its absolutely livable, just gonna take a little getting used to, and maybe a set of earplugs for the really long trips on the hwy:D
  12. Sep 18, 2018 at 1:13 PM
    #512
    BassAckwards
    I think the fact that i went with a side exit before the rear tire really increases the amount of noise in the cab. Love the look though
  13. Sep 18, 2018 at 1:14 PM
    #513
    Roostfactor
    TX panhandle
    Ok, thanks for the clarification and the pics.
    My main concern is that it's not something I did incorrectly which is now confirmed not the case since you had the same issue with URD's y-pipe.
    Does anyone else he have a pre runner and running the URD Y-pipe? If so do you have clearance issues?
  14. Sep 18, 2018 at 1:17 PM
    #514
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    My urd y hits my Cross member on my Tacoma. Posses me off. The urd y on my race truck doesn't.
    jojotoo, Roostfactor and BassAckwards like this.
  15. Sep 18, 2018 at 1:18 PM
    #515
    Roostfactor
    TX panhandle
    And it's a small muffler to begin with 4x9x18" if I guessed. I'm currently using a 4x9x14 for just my resonator, that's not including the Magnaflow tank of a muffler. Sound is just about perfect now for me though.
  16. Sep 18, 2018 at 1:19 PM
    #516
    Roostfactor
    TX panhandle
    Is your Tacoma a pre runner?
    Is it rubbing the same spot as jojotoo's was in the pics?
    Race truck is 4runner correct?
  17. Sep 18, 2018 at 1:27 PM
    #517
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup and yup.
  18. Sep 18, 2018 at 1:55 PM
    #518
    Roostfactor
    TX panhandle
    Thank you VERY much for that info. Now we have confirmation of 2 pre-runners so most likely it's not an anomaly. I will have to make sure I raise the exit on the y to ensure clearance for pre-runners.
    Very positive contribution to performance Tacoma's everywhere.
    Thank you! And thank you @jojotoo for sharing! I wish I would have known before I made yours so I could have insured there was a bit more clearance there.
  19. Sep 18, 2018 at 2:03 PM
    #519
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    You have the afe exhaust right? That is why it is so loud, they are known for having extremely loud mufflers. Although the closer exit probably makes it slightly louder aswell.
    Roostfactor likes this.
  20. Sep 18, 2018 at 2:13 PM
    #520
    BassAckwards
    Yes sir! That is correct. Like roost said, small muffler also doesn't help with the noise level
