Roostfactor’s Equal Length Y-Pipe
Discussion in 'Performance and Tuning' started by 5thGearPinned, Aug 7, 2018.
  1. Aug 8, 2018 at 7:04 PM
    #41
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Added a few details :rofl:
  2. Aug 8, 2018 at 7:05 PM
    #42
    5thGearPinned
    5thGearPinned [OP] Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Roost the legend, I love it. As for the money, I saw exactly what he goes through to do each pipe, and it is no joke. Add another four or five hundred and would be more in line with what it’s really worth. Too much attention to detail and care man. Roostfactor loves doing this, he loves it. And it shows. It was contagious. He is so happy to design, work with metal, apply his theory, talk about it, tweak it, drink, and build something that works like it’s a tuned race part. It was awesome. I can’t wait to go back!
    When we attached his Y-pipe and started the engine without any exhaust whatsoever it sounded just like a full blown race engine. I reved it all the way to redline and back, it was just sweet. Completely tuned and absolutely no hiccups. Just a smooth purr throughout the range, from idle to redline to idle.
    Biscuits, Willbeck, JWL and 1 other person like this.
  3. Aug 8, 2018 at 7:11 PM
    #43
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you can get your hands on one of these, it'll be worth it. :thumbsup:
  4. Aug 8, 2018 at 7:17 PM
    #44
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Oh I am getting my hands on one thats for sure. My wallet begs me for mercy every night but I keep telling it just one more...
  5. Aug 8, 2018 at 7:18 PM
    #45
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The TW struggle is real
  6. Aug 8, 2018 at 7:20 PM
    #46
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I’m not sure if I have spent more on the truck or mods and at this point I am afraid to start tallying it up. I just know this ypipe is a work of art, even more beautiful than the supercharger itself.
  7. Aug 8, 2018 at 7:21 PM
    #47
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Don't tally it up. Trust me. It's not pretty.
  8. Aug 8, 2018 at 7:22 PM
    #48
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That is amazing! Your too much dude!!!
    @5thGearPinned still has stock manifolds and it still sounds good. Of course headers are best but for Cali I dont know if I would want to swap headers/manifolds out every smog check.
    Thanks Roscoe!!! I love I love it!
    I believe he may be on someone's list?!
  9. Aug 8, 2018 at 7:23 PM
    #49
    Roostfactor
    TX panhandle
    Wait til I hack my supercharger up!
    5thGearPinned[OP] likes this.
  10. Aug 8, 2018 at 7:26 PM
    #50
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I need to get a small slab of land in another state with a mailbox so I can register my truck there.
    In all seriousness, the ypipe is already not carb compliant, but they would have to look for it. Its easy enough to switch back. I’ve read the urd headers are quiet the pita to install. Would make swappjng back and forth very tedious I think. I’ll try the ypipe first and see how it goes.
  11. Aug 8, 2018 at 7:31 PM
    #51
    Roostfactor
    TX panhandle
    Plus the stock manifolds have cats and no need for any o2 sims or ecu trickery.
    Yes the headers are a fun install, just ask @White lightning boosted and @crashnburn80
  12. Aug 8, 2018 at 7:54 PM
    #52
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Only problem is my driverside header is a botched job. The trans bracket mount doesn’t line up because the ding bats didn’t weld the cat on straight. It also causes my catback to rub on the driveshaft support bearing crossmemeber. I wonder if I should just put the stock headers back on, I have an extra set.
  13. Aug 8, 2018 at 8:06 PM
    #53
    Roostfactor
    TX panhandle
    Road trip! I'll fix it and you wont have to pay shipping.
    You'll have to send me a couple pics of how its offset. I wonder how much it will affect the angle of the y-pipe. If its tweaked how does your y-pipe bolt up to the header flange?
    Do you have stock y or URD?
    Murphinator[QUOTED] likes this.
  14. Aug 8, 2018 at 8:22 PM
    #54
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    We need to make a fake shroud that looks like a manifold to conceal headers for our cali brothers.
  15. Aug 8, 2018 at 8:27 PM
    #55
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Ok so stock was on there. I ended up having to cut out the studs in the header to get the ypipe off. Could not get it seperated even after cutting the nut off. Just on the drivers side, which is the side that is slightly tweaked. Passenger side came off easy peasy. The urd pipe is installed now. I could send you pics of it and you can kind of tell, it’s a few degrees off. Everything bolts up except that bracket that goes to the transmission is just off enough you cant get the bolts to go in straight.
    That would be a long road trip and if I could take the time off work I would do it in a heartbeat.
  16. Aug 8, 2018 at 8:27 PM
    #56
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    You know I bet if I taped a $100 bill to the frame the smog tech wouldn’t say sh*t
    :D
  17. Aug 8, 2018 at 8:35 PM
    #57
    Roostfactor
    TX panhandle
    I know, I've done the road trip to Victorville and Landcaster 3 times in this last year.
  18. Aug 8, 2018 at 11:39 PM
    #58
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Beautiful work of mechanical art.
    As someone who recently destroyed their stock skids, is there adaquate clearance between the Trans and skid mount location on the cross member for the Y-pipe to cross without interference?
    Biscuits and Roostfactor like this.
  19. Aug 9, 2018 at 5:38 AM
    #59
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Did you try loosening the two bolts that hold the bracket to the transmission? There’s a little play in those holes.
    When I did mine, I loosened those and re-tightened them after everything else was tightened.
    Roostfactor likes this.
  20. Aug 9, 2018 at 5:55 AM
    #60
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I can’t get them in even. Id have to drill new holes in the bracket basically. I had to buy a new bracket and bolts because I noticed after the headers were done that driverside went missing. I know why now, its physically impossible to get them all bolted up as it sits right now :/
    loginfailed[QUOTED] likes this.
