Roostfactor’s Equal Length Y-Pipe
Discussion in 'Performance and Tuning' started by 5thGearPinned, Aug 7, 2018.
  1. Oct 14, 2018 at 9:34 AM
    #581
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    Not to derail the thread... But it's funny you say that, my URD setup totally sounds like it leaks somewhere. I've checked up and down and cant find anything. when I rev the engine I get a blow off valve type of sound and when cruising there's a light hiss present. Looked everywhere for leaks but can't find anything. Even if there isn't a leak, i still can't help but worry about it sounding the way it does
  2. Oct 14, 2018 at 10:33 AM
    #582
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Do you have URD headers?
  3. Oct 14, 2018 at 10:38 AM
    #583
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Gadget mentions using his manifold-to-ypipe gaskets when using the urd ypipe....instead of factory gaskets to prevent leaks at that junction. Self marketing or the truth, u can decide.
    Also, the slip fit on the urd ypipe is lousy. Just weld that seam up instead of using the slip fit clamp. The welded ypipe will be removable like that.
    Stryker420 likes this.
  4. Oct 14, 2018 at 10:39 AM
    #584
    Roostfactor
    TX panhandle
    Remflex 6006 gaskets are awesome!
    JWL, BassAckwards and Stryker420 like this.
  5. Oct 14, 2018 at 11:34 AM
    #585
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    I have the URD equal length long tube headers.
    I did not know it was still removable with that clamp welded together. I will be getting this done soon, then...
  6. Oct 14, 2018 at 5:12 PM
    #586
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    His gaskets are far superior. I worked at an exhaust shop. They are much better quality and should last much longer. I wouldn’t use them on an oem setup cause it’s not needed, but would definitely use them on aftermarket headers and exhausts
    Torspd, jojotoo and SUMOTNK[QUOTED] like this.
  7. Oct 14, 2018 at 7:28 PM
    #587
    Roostfactor
    TX panhandle
    just be careful not to overtorque them or you will bend the flange. You don't have that potential problem with the Remflex since it seals the whole flange area and not just a donut.
    Murphinator likes this.
  8. Oct 14, 2018 at 7:47 PM
    #588
    glorifiedwelder
    jason
    Santa Clarita, ca
    I was gonna mention the bent flange part.
    My problem With the two hole gaskets is they generally fail sooner because they are designed to work with a much larger sealing surface than a header with a recessed flange like the urd’s can offer. You’ll get a decent amount of time out of one on a street truck (maybe 12-18 months) but they don’t seem to last near as long on an off-road truck.
  9. Oct 14, 2018 at 10:02 PM
    #589
    Roostfactor
    TX panhandle
    Have you tried the remflex graphite gaskets? I totally understand what you mean about the standard flange gaskets but these are pure reinforced graphite. I have had exceptional experience with them.
  10. Oct 15, 2018 at 3:23 PM
    #590
    glorifiedwelder
    jason
    Santa Clarita, ca
    I have used graphite 2 hole gaskets in the past on customer cars with good results, but I’ve also had more cars than I could ever count come in with 2 hole gaskets on a recessed flange that were way blown out. I definitely think your choice of two hole gasket is the best option for that style gasket paired with that style flange and have no doubt they will hold up for a decent while. I have an extreme distaste for any form of exhaust leak. I was gonna they v-bands on my urd headers but just don’t have the time to rework my y-pipe or build new support brackets off the motor. Hopefully soon I’ll be back to spending as much time as I want fiddling with parts on my own truck.
    Torspd and Roostfactor[QUOTED] like this.
  11. Oct 15, 2018 at 3:28 PM
    #591
    Roostfactor
    TX panhandle
    I fully understand that one. I was going to install v-bands on my header to y-pipe connection but just as you said, I would have to fabricate a new trans to header bracket and add a flange to the header.
    It works fine as is.
  12. Oct 15, 2018 at 4:46 PM
    #592
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I cheated. Added a short length tubing and a v-band, slipped over the OEM header outlet. Then made the y-pipe to fit from there. Not the "purest" choice, but damn easy. Kept the trans support.
    Roostfactor[QUOTED] and Hawk373 like this.
  13. Oct 15, 2018 at 5:04 PM
    #593
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Roostfactor , could you remind me. Your y-pipe is 2.25" or 2.5"?
  14. Oct 15, 2018 at 5:30 PM
    #594
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    @Roostfactor Do you have any insight on why my URD setup hisses? You asked if I had the URD headers so I thought you might have some ideas
  15. Oct 15, 2018 at 6:06 PM
    #595
    Roostfactor
    TX panhandle
    2.25"
    Torspd[QUOTED] likes this.
  16. Oct 15, 2018 at 6:10 PM
    #596
    Roostfactor
    TX panhandle
    I think everyone with the URD headers has a bit of a tick/hiss sound at lower rpm. I thought I had an exhaust leak for awhile but after chasing imaginary leaks and talking with others it appears it's just a common sound.
    Now, if you have not welded the slip fit on your y-pipe that may be causing your issues.
    JWL[QUOTED] likes this.
  17. Oct 15, 2018 at 6:56 PM
    #597
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My URD Y had the same sound. I think it’s partly due to it being unequal length. It doesn’t do it anymore though.
    JWL and Roostfactor like this.
  18. Oct 15, 2018 at 8:00 PM
    #598
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    I think I’ll be getting that slip fit welded ASAP. I appreciate the reply as my current setup has me worried and a little regretful that I had it installed in the first place.
    For you, did this resolve after the roosterfactor y pipe? I’m hoping that welding the slip fit will be the solution
    loginfailed[QUOTED] likes this.
  19. Oct 15, 2018 at 9:02 PM
    #599
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My slip fit was welded and it made that sound. It’s greatly reduced by making the y-pipe equal length. @Roostfactor made my URD pipe equal length and the thing sounds totally different, much improved in every way.
    The darker sections are what’s remains of the URD pipe.
    JWL[QUOTED] and Roostfactor like this.
  20. Oct 15, 2018 at 9:53 PM
    #600
    Roostfactor
    TX panhandle
    JWL likes this.
