rotating retrofit
Discussion in 'Lighting' started by AJ4X4, Mar 17, 2012.
  1. Mar 17, 2012 at 7:06 PM
    AJ4X4
    AJ4X4 [OP] Well-Known Member
    White 2010 TRD Off Road Double Cab
    I've searched and can't find what I'm looking for. I need to rotate my mini h1s because they aren't level. How can i do this?
  2. Mar 17, 2012 at 7:43 PM
    dmb
    dmb Well-Known Member
    Boise, ID
    Do you mean up-down-left-right...or...clockwise-ctr clockwise rotation? Or both?
    After I did my mini h1 retrofit I had to ajust everything. I ended up trimming the locking adapter plate so that it could rotate and thus allow the projector to rotate. Then I tightened everything back down and put back on the truck. I turned the lights on and used a screwdriver to move the adapter plate enough to line everything up.
    Hope this helps!
