Rotating Tires
Discussion in 'Wheels & Tires' started by Mz_TazComa, Oct 24, 2008.
  1. Oct 24, 2008 at 3:56 PM
    Mz_TazComa
    Mz_TazComa [OP] Well-Known Member
    Long Island, NY
    '16 D-Cab TRD Sport LB
    I just rotated the tires on my '06 DC. I have a little under 20k on them. There was some controversy as to whether we should rotate them from front to back or diagonally. I ended up doing them the way I thought, but I won't say which way until I hear some thoughts from you guys.
    So which is it....front to back or diagonal?
  2. Oct 24, 2008 at 4:00 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Owners manual says front to back.
  3. Oct 24, 2008 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Driver side rear to passenger side front. Passenger side rear to driver side front. Driver side front to driver side rear. Passenger side front to passenger side rear.
    OR
    front to back. I havent seen any advantage to doing it the first way.
  4. Oct 24, 2008 at 6:41 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    If you are staring to get feathering a little then diag is the only way to go and i think that is the best way anyways
  5. Oct 24, 2008 at 6:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i always go front to back, and then every 6k miles, i'll go diagonal. never had a problem doing it either way though.
  6. Oct 24, 2008 at 6:50 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ditto...plus if a tire is wearing one way and u keep doing the same pattern over and over, its just gonna keep getting worse at that one place
  7. Oct 24, 2008 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep, and thats when you know its probably time for an alignment also.
  8. Oct 24, 2008 at 6:55 PM
    The_Hodge
    SC
    i'm just talkin about tires here, will.i.aint haha
  9. Oct 24, 2008 at 6:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    true......but its just good idea to have an alignment check if you are having weird tire wear..........no sense in wearing a tire out if all thats needed is an alignment.
    will.i.aint is pretty funny tho.:D
  10. Oct 25, 2008 at 3:57 AM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    I'm gonna add my 2 cents here because this happened to me about a year ago with my wifes 2005 Tucson.
    Took it to STS for an oil change and I knew it was about time to have the tires rotated since they hadn't been since the car was new. Odometer approx. 20,000 and the tires all had nice even wear.
    Ok, I watched them rotate the tires and they did right passenger rear to front driver side (criss cross). I had aways done front to back. About two weeks later, my wife tells me that she can feel a vibration. Great. I look at the tires and they now have a real weird pattern on them and basically the tires are f'ed up and now need new ones. Ended up getting tires from another place and the guy there told me never to rotate them like that again. $400 for 4 Cooper rain tires. They are working out very nice so far with about 10,000 miles on them.
    I don't know who is correct but I never had a problem like this before with any car because I always did front to back.
    So, if you do the cris cross thing keep an eye on your tires for something like this.
  11. Oct 25, 2008 at 4:03 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    front to back every 5k trust me that is best
  12. Oct 25, 2008 at 4:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I always do them front to back and the cardinal rule of thumb that I've been told over the years..... is because the tread/tire internals can build up a 'pattern' from traveling in a certain direction. Front to back keeps the tread in that same direction/pattern. When you upset that pattern - you can have problems (like you experienced).
  13. Oct 25, 2008 at 12:21 PM
    trcksr4grls
    trcksr4grls Prayers for Bill and Michelle
    Texas
    Debadged 08 Super White Prerunner
    I have always done front to back.....
  14. Oct 25, 2008 at 4:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Keep in mind some tires are directional. Not all terrains.
    I do what ever I feel at the time. Front to back once or twice then criss cross pattern.
  15. Oct 25, 2008 at 5:23 PM
    Mz_TazComa
    Long Island, NY
    Thanks guys and gals. I ended up doing them diagonal and so far haven't had a problem, but I will keep an eye (and ear) out for any vibration.
    I remember seeing that for front wheel drive toyota recommends moving the back to front and the front to the opposite back. For rear wheel drive it's front to back and back to the opposite front. For non-directional tires, it's diagonal.
    I was still curious to see what everyone else was doing and if anyone had any bad experiences a certain way. After reading the responses, I'm sorry I did the diagonal now and just hope my tires are ok.
    Thanks again.
