Rotor Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by TPG013, Jan 1, 2015.
  1. Jan 1, 2015 at 4:50 AM
    TPG013
    TPG013 [OP] New Member
    Sayville, NY
    SR5
    Hi, newbie here.
    I have searched the forum with no success.
    I am looking for where I can find brembo blanks for my truck. All I seem to find is blanks for 2wd not 4wd.
    04 SR, 3.4, manual. Any help is appreciated as are other rotor recommendations.
  2. Jan 1, 2015 at 7:27 AM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
  3. Jan 1, 2015 at 10:08 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Why not upgrade to the tundra brakes? I performed this upgrade on my 2000 4runner and my 04 tacoma. Easy bolt on upgrade.
  4. Jan 1, 2015 at 2:04 PM
    TPG013
    Sayville, NY
    SR5
    Thanks for the info.
    Not interested in the Tundra swap. Overkill IMO.
  5. Jan 1, 2015 at 7:01 PM
    unixadm
    I've considered this. Which Tundra brakes did you go with since there are two variations of them. I remember back in 2002 when my Tundra had a TSB performed, they swapped the rotors and calipers to larger ones.
    Also has anyone added the Tundra master cylinder? I would imagine the bore size of the master cylinder is larger on the Tundra. I have read that people have a lower pedal with the Tundra brakes since the calipers take more fluid displacement to bite.
  6. Jan 1, 2015 at 7:28 PM
    68dave
    Dave
    I have the 199mm's on my 00 4runner and the larger 231mm's on my 04 tacoma. Never had to change the mc's on either truck. On the tacoma i had to purchase new banjo bolts from Wheeler's offroad. I upgraded the tacoma to stainless steel brake hoses too. Wheelers offroad sells the banjo bolts and hoses in a kit. Both size calibers cleared my oem 16" alloys. The tundra kit is a awesome & easy upgrade for both vehicles. I just purchased a 3rd 4x4, a 02 4runner and i'm about to upgrade the brakes on that as well.
  7. Jan 1, 2015 at 8:33 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    Are these the hoses your referring to? Are these compatible with all the 231mm calipers?
    I hope to be upgrading to tundra brakes in a couple months.
  8. Jan 1, 2015 at 8:45 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Rockauto has some brembo for 4wd. As well as many others...
  9. Jan 1, 2015 at 11:35 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the tundra upgrade is a little overkill unless you tow, OR, or drive like a bat out of hell :)
    Amazon sells them
    http://www.amazon.com/Brembo-25513-...20183744&sr=8-2&keywords=brembo+rotors+tacoma
    here is Brembo's support page for our year
    http://brembo.mycarparts.net/products/Brembo-09819380?product_application_id=4786668807
    I actually went with EBC rotors/pads when I re-did my brakes in September, have no complaints. my stock rotors lasted me 10 yrs and then had some warping.
  10. Jan 2, 2015 at 4:19 AM
    68dave
    Dave
    Yea that's the hoses, i purchased the rear hose as well. Brake pedal is firm and high.
  11. Jan 2, 2015 at 4:26 AM
    68dave
    Dave
    I do tow with both my trucks.
  12. Jan 2, 2015 at 3:20 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    in your case it's a no-brainer :)
    but the OP I doubt tows or wanes from the "paved" road much :D
    Off-topic. Do you use electric brakes on your trailers at all 68dave?
  13. Jan 2, 2015 at 4:39 PM
    68dave
    Dave
    Yea, the Casita camper has electric brakes.
  14. Jan 3, 2015 at 12:43 PM
    TPG013
    Sayville, NY
    SR5
    The Amazon link is for a prerunner which is 2wd and mine is 4wd. Are the rotors the same?
    The brembo link doesn't work.
  15. Jan 3, 2015 at 2:13 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yes rotors are the same (6-bolt)
    I searched by info http://brembo.mycarparts.net/ and just click the links for your model. They all give the same results you just have to make sure to pick the one for 4wd OE replacement (there are 2 versions but doubtful you'll need UV coated)
  16. Jan 12, 2015 at 11:07 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    What year tundra brakes would I need if I wanted to do this upgrade?
  17. Jan 12, 2015 at 11:53 AM
    68dave
    Dave
    The earlier tundra's had the 199mm then Toyota upgraded them to the larger 231mm. I can't recall the exact years but I do know newer tundra's are now 5 lug so obviously they won't work. Use the search bar, a lot of info here about this swap.
  18. Jan 12, 2015 at 11:55 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thanks!
