Rotor replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiwiyyc, Sep 15, 2023.
  1. Sep 15, 2023 at 11:49 AM
    kiwiyyc
    kiwiyyc [OP] Well-Known Member
    Calgary, AB
    2020 Tacoma TRD Sport Premium 6MT, Cement
    Howdy,
    My 2020 TRD Sport is in at the shop and has 63,500 km/40,000 miles on it. I’ve been getting some vibration when braking at highway speeds down hill. The dealer says that the pads are fine but the rotors need replacing. That doesn’t seem like a lot of mileage on the rotors but I’m not sure if that is “normal” or not?
    Thanks for the feedback!
  2. Sep 15, 2023 at 12:15 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If your wheel lugs were over torqued at any point, or you hit a lot of water with hot brakes, it could happen. I have a 21 Highlander with the exact same issue at 40K miles. I just replaced my Taco rotors at 70K and they were perfectly fine.
  3. Sep 15, 2023 at 12:19 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Low mileage for rotors to be bad/worn out, but really depends on how hard you were using the brakes in those 40k miles (towing, etc.).
    BTW you should always replace pads when you replace rotors.
  4. Sep 15, 2023 at 12:39 PM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Agree above: lug torque & hard braking. Fronts already do the majority of braking your 4500+lbs, so if the 40,000 mi driven is a lot of stop & go, it’s reasonable to believe they’re warped.
    Always a good idea to get a 2nd opinion though, and the dealer will charge you top dollar.
  5. Sep 15, 2023 at 12:48 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Lots of factors like mountains, towing, driving habits, etc.
  6. Sep 15, 2023 at 1:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if you get new rotors get new pads.
    LeakyAC and kiwiyyc[OP] like this.
  7. Sep 15, 2023 at 1:48 PM
    kiwiyyc
    Calgary, AB
    Thanks all. Just talked to the dealership and there’s still 8 mm on the pads so only about 30% worn. My advisor has recommended waiting to replace the rotors until the pads are more worn so that everything is replaced at the same time.
    I do a lot of mountain driving, plus stop and go as a DD along with a bit of towing so based on the comments here, I’m guessing this will be an ongoing issue. Are there better rotor upgrades available that would minimize this happening so quickly?
  8. Sep 15, 2023 at 1:51 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do people not turn down rotors anymore?
  9. Sep 15, 2023 at 2:16 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I just had my 4Runner rotors turned, but that was a mom and pop shop.
    I think turning rotors is going the way of the tire plug..
    Taco22trdor and MannyS like this.
  10. Sep 15, 2023 at 2:26 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a vibration at 40K miles on my factory brakes. Normally like to stay OEM but put PowerStop on last summer and am very happy. Also I am all on pavement so drilled and slotted is fine for me.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
    Also, if you are replacing rotors I would want to put on new pads too.
  11. Sep 15, 2023 at 3:45 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    If/when you get new rotors, retorque the lug nuts yourself when you get home. You can bet a stealership wrench monkey doesn't know what a torque wrench is and will just over torque your new rotors. Better yet, just do it all yourself. Swapping rotors is easy on this truck.
    Big tall dave and Koolbreeze7 like this.
  12. Sep 15, 2023 at 3:55 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Waste of time and effort
  13. Sep 15, 2023 at 6:58 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    The rotors are made in China and better just to get new ones. LOL, I don't know this for sure but they are relativity inexpensive these days compared to what they were back when I was turning wrenches.
  14. Sep 15, 2023 at 7:02 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
  15. Sep 16, 2023 at 11:32 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i go to Napa, they have good, better and best to chose from.
  16. Sep 16, 2023 at 11:59 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 241,000. My rotors have been turned 2 or 3 times due to vibration. I'll need new rotors next time they need to be turned.
  17. Sep 16, 2023 at 12:37 PM
    Electrathon
    Electrathon Electrathon
    Aaron
    Portland OR
    2023 Tacoma trd
    All the little easy stuff. Locking console box, led interior lights, bed lights, gas cap holder, wide angle split mirrors, sequential mirror lights,
    With the cost of labor, compared to the cost of rotors made in China, it is sometimes cheaper to just replace them.
    Big tall dave likes this.
  18. Sep 16, 2023 at 4:13 PM
    ernscott
    2021 Tacoma
    If they warped when they were thick - they will warp easier when they are thiner.
    Big tall dave and shakerhood like this.
  19. Sep 18, 2023 at 7:09 AM
    Viper70762
    Viper70762 Active Member
    Shaun
    2017 Toyota Tacoma SR5
    OTT tune, 1.25 wheel spacers
    Check your rear brakes and make sure they are adjusted properly. If they aren't then your braking is all done with the front brakes only
  20. Sep 18, 2023 at 7:34 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    Turning rotors are a liability. Our shop sold the machine as too many shops wanted out of spec rotors turned. Yeah, just say no doesn't always work the way you think.
