rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jr124gamboa, May 22, 2011.
  1. May 22, 2011 at 2:14 PM
    jr124gamboa
    jr124gamboa [OP] Well-Known Member
    socal
    07 4x4 sr5
    airride airbags, bedliner,
    im planning to remove and get the rotors turned but ive never done it in my 2007 taco....wondering if anyone has specific instructions like step by step to get it done
    thanks
    im planning on doing this tomorow
  2. May 22, 2011 at 2:24 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    they come right off.....with a swift kick
  3. May 22, 2011 at 6:43 PM
    ice.xiv
    ice.xiv Member
    06 TRD Access Cab 4x4 6Spd
    Remove the wheels. I think the lugs are 21mm.
    Remove the 12mm bolt that holds the brake line, it's where the brake line transitions from rubber to steel.
    There are several bolts on the backs of the calipers, you will need to remove 2 of them. I think they are 14mm or 17mm. They're the larger 2 of all the bolts, they hold the caliper onto the knuckle/hub. You'll want a breaker bar for these.
    Pull the caliper off the disc and either hang it off something with safety/bailing wire or set it on top of something so that it's not being suspended by the brake line.
    Discs should pull right off, but if they don't than kick one side harder and harder until it breaks loose.
    I'd recommend just buying new discs. I've never had good experiences with getting discs turned and it isn't much more expensive to replace them completely with higher quality discs.
  4. May 22, 2011 at 7:06 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    If you want to try getting them turned, go here http://www.oreillyauto.com/site/fi/cities/CA.oap They do it for 5 bucks a rotor. You can usually only do it once before it falls out of spec; I have done it numerous times and never had an issue.
  5. May 23, 2011 at 12:52 PM
    jr124gamboa
    socal
    07 4x4 sr5
    hahaha a swift kick
    thanks for all the info i thought it was going to be more difficult
