Rough Country vs Gator Tri-Fold Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by Echesanti22, Aug 9, 2017.
  1. Aug 9, 2017 at 6:36 AM
    Echesanti22
    Echesanti22 [OP] Well-Known Member
    2017 Toyota Tacoma SR5 - Blazing Blue Pearl
    Hello,
    Trying to decide on a Tonneau cover for my Taco. I have been researching and I came accross these two:
    http://www.roughcountry.com/toyota-soft-tri-fold-bed-cover-44716c.html
    https://www.amazon.com/dp/B00I11U3D4/_encoding=UTF8?coliid=I3AYJA4X4X0N1M&colid=3920P20CB8EEC
    What do you guys think? Are either of these worth it? Or should I look elsewhere? If so, would you please point me in the right direction?
    Thanks in advance.
  2. Aug 9, 2017 at 6:48 AM
    kluge9
    kluge9 Well-Known Member
    Andy
    19 DCSB OR MT
  3. Aug 9, 2017 at 7:07 AM
    2017tacotrd
    2017tacotrd Member
    2017 Tacoma trd
    I have the rough country trifold cover. I bought it off of Amazon it took a total of 15 minutes to install and I love it. It's been through 2 rain storms And I have hit multiple times with my pressure washer no leaks. It was 249.99 On Amazon but I did not pay the price. I had give cards which paid for it
    Nostr0m0 likes this.
  4. Aug 9, 2017 at 7:17 AM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    My two cents as I went with the Gator - quick easy install, works with the utility rails (came with the brackets) and haven't had any issues with leaks or anything like that; but it's only been a couple months, and it seems like the vinyl has already sagged some. No flapping issues or anything like that, just that you can now clearly see the outlines of the bows. Not really a functionality problem, more like at first it looked like a high quality cover, now it looks like a cheap cover (of course, it was a cheap cover).
  5. Aug 9, 2017 at 7:27 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    Looks like your going cheap. I started out the same way but ended up with the Extang Encore at 899.
  6. Aug 9, 2017 at 7:57 AM
    Echesanti22
    I appreciate all the information guys, ill keep researching and make an educated decision.
  7. Aug 9, 2017 at 8:07 AM
    Rico853
    Rico853 Member
    Rico
    2017 TRD OR
    CusterFan likes this.
  8. Aug 9, 2017 at 8:37 AM
    Bliz
    Bliz Active Member
    '17 Tacoma TRD Off Road 4x2 DCSB AT
    I've had the Gator installed for about 4 months. No complaints here. This is my first truck so I don't have much to compare to. It does seem to flap quite a bit at 45mph and above. It's not distracting and I can't hear it but I don't know if other soft tonneaus do the same since this is the only one I've ever had. Very easy to install and quick to take down if need be. Water seems to stay out pretty well. For the price, it's great.
  9. Aug 9, 2017 at 9:33 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    A recurring theme I've always found with tonneau covers is that, while they are all extraordinarily overpriced, you get what you pay for. Might be smart to spend a little more for a higher-quality design.
    Also - security, price, user friendly, bed space when open. Pick any 3.
  10. Aug 9, 2017 at 10:49 AM
    Bolsillos5624
    Bolsillos5624 Needs more money for mods
    Shannon
    2017 Tacoma Off Road Access Cab
    Bak Revolver X2 Tonneau. Cover Custom TRD Change Holder
    I have a BAK Revolver X2 on my 17' OR Access Cab. It's a hard roll up like the Truxedo tonneau, but it uses all edpm rubber seals and doesn't use Velcro like the Truxedo version does. It keeps everything dry, no holes to drill and just drops the factory rail down a couple of inches with new brackets which are included. Very easy install. You can operate the tailgate with the cover closed, and since the sides of the cover lock down as well it keeps the stuff in your bed very secure. It's also super low profile which makes it look even better. Best part is that it doesn't block your rear window when it's rolled up like the trifolds do. It's not cheap at around $850 bucks, but the quality, ease of use and looks of this cover are worth the price tag. I got mine at Tonneaucoversworld.com and you can haggle the price down with them. It's easy and shipping is free.20170809_134204.jpg 20170809_134300.jpg
    CusterFan, ToyoDrew and techbill like this.
  11. Aug 24, 2017 at 6:47 PM
    Colton58D
    Colton58D Well-Known Member
    2017 Tacoma Trd Pro
    These cheap versions will last years. How many depends on your environment. I have a Gator tri fold pro which I did a write up on with some pictures. Easy to install but I will be honest, most soft trifold install the exact same. If you are set on a soft tonneau like I was don't spend too much money. They are not as durable as a hard one by no means but they do the same job. I am extremely satisfied with mine. The customer service was great. If you have any questions about gator hit me up.
    DubfromGA likes this.
  12. Aug 25, 2017 at 4:30 AM
    Echesanti22
    Thanks for the info man. I take you have the Gator. You stated that I should hit you up, do you sell them or just for information?
    Thanks
  13. Aug 25, 2017 at 8:27 AM
    Zach.RealTruck
    Zach.RealTruck Well-Known Member
    Zach
    16 Tacoma Inferno SR5
    Lift, wheels, tires, floor liners, tonneau cover, and bed rug.
    We don't sell the Rough country Tonneau but we are sister companies with Gator. They are under are umbrella. I won't give you a biased review they will be nearly identical covers. They are both considered entry level soft tri-fold covers. If you are looking to separate differences then the Gator Tri-fold Pro would be a better choice between the two. It has a Matte finish, more durable frame, and the rear clamps are cam lock style so they detach easier than the standard tri-fold.
    As others have said you can't go wrong with any of the soft folding covers. They will all be relatively similar in design, with a few upgrades as you go from $240ish to $400 range.
    If you have questions regarding any type of Tonneaus please let me know. I've had every type on my vehicle at some point.
  14. Aug 25, 2017 at 7:47 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    @Zach.RealTruck do you have a recommendation on a vinyl roll up ... since I have a 5' bed I'd like the minimum intrusion into the bed length when it's rolled up, but of course, I want it leakproof, no flapping or sagging, and good security. Considering Truxedo or Access low profile tonneaus. Thanks ...
  15. Aug 26, 2017 at 4:43 AM
    Zach.RealTruck
    Zach
    So with the soft roll ups, you will have "out of sight out of mind security". Whether you go with a soft cover or hard cover when driving at high speeds you will get some bounce due to the wind shearing off the top of the cab and slamming into the bed, this is normal and you can expect it of just about every cover unless you have a solid one piece. As far as soft roll ups go Truxedo or Access would be the leaders in this category. It would come down to budget and what upgrade you deem necessary. The LO pro from Truxedo is going to be the top of the standard for the roll up covers. If you have more of a budget in mind and want to get something less expensive the Truxport works really well on our trucks. This is because it actually sits on top of the bed rail and still allows us to use most of our deck rail.
    Let me know if you have any more questions.
    cak and dman100[QUOTED] like this.
  16. Sep 28, 2017 at 8:34 AM
    cak
    cak Well-Known Member
    Palo Alto, CA
    2017 V6 4x4 SR5 ACLB
    OP, did you pull the trigger on any of these? I find myself in the same position - new truck, need a tonneau, don't want to spend too much ...
  17. Sep 28, 2017 at 11:43 AM
    El Chap the Taco
    El Chap the Taco Well-Known Member
    2017 TRD OR MT
    just look for a factory tonneau off craigslist, you can probably find one for a few hundred dollars and you get the security, and locking features of a hard tonneau with the price of a soft.
    cak likes this.
  18. Sep 28, 2017 at 12:47 PM
    cak
    Palo Alto, CA
    Not so easy in the Bay Area, apparently.
  19. Oct 7, 2017 at 6:01 PM
    cak
    Palo Alto, CA
    Found an open box Gator tonneau for about 1/3 retail. Arrived today ... no one told me that it needs a special clamp bracket system to work with the factory cargo rails. Maybe they should have been supplied and were missing because "open box". Digging around the web for the supplied part number, I get pointed to "American Tonneau" and "Extang", who seem to provide exactly the same tonneaus, exactly the same install instructions, as Gator - except for the logo. It's possible that these are all subsidiaries or associated with "Truck Hero".
    For whatever that's worth.
    Now I have to wait two more days for the bracket kit. Sigh.
  20. Oct 9, 2017 at 7:18 PM
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    i have the same one, but i get leaks at the foam pads when it rains. I think it has something to do with the pads lining up with the gaps on the bed trim, but not sure. i'm not talking a lot, just small trickles. have you seen anything like that?
