Rough idle after warm up--2.7 1999 4X4 5 spd.
Discussion in '1st Gen. Tacomas (1995-2004)' started by wee, Jul 30, 2022.
  1. Aug 25, 2022 at 2:49 AM
    wee
    wee [OP] Well-Known Member
    No not yet....I found a post on a Toyota forum that said the plate does adjust the idle. If it doesn't settle down over the next couple of weeks I'll try adjusting it. I really think the issue is I put one on meant for an automatic which probably has the factory idle set just a tad bit higher. If it was a $300 OEM part I would take it back off and exchange but for only $35 I think I'll try to adjust it first.
    I will report back in a couple of weeks, I don't put many miles at all on this truck anymore so it will take awhile to figure it out.
    Brian
  2. Aug 25, 2022 at 2:52 AM
    KT74
    KT74 Member
    Best of luck! Driving is crucial to idle relearn so hopefully it adjusts itself in a few weeks and isn't another issue. Will keep an eye out for your update.
  3. Oct 11, 2022 at 5:52 PM
    wee
    Driving it hasn't fixed the odd idle issue. When I first crank it it idles fine....Even afther I have driven it. But once I start down the road and pull up to a stop sign it idles too high just a little 1000 rpm. I'm guessing it's the cheap iac valve from Amazon. I ordered one for a manual but they shipped one for an automatic.
    Brian
  4. Oct 15, 2022 at 6:41 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    Every time you disconnect the battery the ECU has to relearn.
    You really should use the correct part. It does make a difference.
  5. Oct 15, 2022 at 1:12 PM
    wee
    The last ebay one worked like a charm for 3 or 4 years....Just didn't get lucky with this one. I think I clean the old one and try it again.
    Brian
  6. Oct 15, 2022 at 1:19 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
  7. Nov 30, 2022 at 2:58 PM
    wee
    Well I fixed it....I bit the bullet and put an OEM on it...Back running like a charm. I pick up my new Tacoma on Friday and this one is now for sale.
    Brian
    THatt likes this.
  8. Dec 6, 2024 at 1:45 PM
    wee
    Believe it or not my Dad bought a 99 Tacoma with a 2.7 and is having the same issues, I googled and came up with this thread. First think I told him was put a new IAC, it still does it.
