Rough idle and wont rev over 2100 RPM after intake gaskets replaced
Discussion in '1st Gen. Tacomas (1995-2004)' started by freeone56, Jun 29, 2013.
  1. Jun 29, 2013 at 7:27 PM
    freeone56
    freeone56 [OP] Member
    Washington/Oregon
    Tacoma 4x TRD SR5
    3" lift,airbags,upgraded shocks,e-locker rear diff,winch
    I got a lean number 1 cylinder bank code with CEL on my 99 tacoma with the 3.4. I checked the intake manifold gaskets and replaced them. They were falling apart. Replaced the plenum gaskets also. Tried to clean the throttle body and IAC with gasoline because I didn't have throttle body cleaner and no ride to town. Now it starts up OK but idles rough and wont rev over 2100 RPMs. What did I mess up that would cause these symptoms? Any help would be appreciated.
  2. Jun 30, 2013 at 1:16 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    did you disconnect the battery before you did the work? try doing this now and let it reset for 1/2 an hour.
  3. Jun 30, 2013 at 1:29 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Did you disconnect the tps?
  4. Jul 1, 2013 at 10:26 AM
    freeone56
    Washington/Oregon
    Tacoma 4x TRD SR5
    First thank you for replying to my post. I did disconnect the battery and the TPS at two different times and let it set for about an hour. Didnt get any codes after the battery disconnect, but did when I disconnected the TPS. After doing more research I'm under the impression that I may have messed up the TPS by not removing it from the throttle body when I cleaned the throttle body. They are reasonably cheap so I will proly replace it. Does it sound like I'm on the right track.
  5. Jul 1, 2013 at 11:41 AM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    Sounds like a tps problem, maybe a MAF issue. Did you clean the MAF with gasoline?
  6. Jul 2, 2013 at 9:23 PM
    freeone56
    Washington/Oregon
    Tacoma 4x TRD SR5
    I didn't clean the MAF this time. I did a month or so ago but I used MAF cleaner. I think you are right about the TPS. I understand it isn't supposed to be cleaned just replaced. Going to replace the TPS next. Hope that fixes it.
  7. Jul 5, 2013 at 4:43 PM
    freeone56
    Washington/Oregon
    Tacoma 4x TRD SR5
    I checked the TPS. It is in spec as far as ohms. Lastly I checked the MAF sensor and it seemed a little dirty. I cleaned it and it appears that was what was messing up the rpms. Seems to run fine now, but im waiting on my K&N air filter to dry so I can re-oil it and test drive it. I think with the air intake tube off the air box it collected some dust from the wind even though I had tried to cover it with a clean rag. Man it had me stumped and it turned out to be simple. Thanks guys for all your help. I sure learned a lot with this seemingly simple intake gasket replacement.
    Freeone
  8. Jul 5, 2013 at 8:00 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    Glad it was something simple! Over oiling The k&n can dirty the MAF pretty quick, oil gets on it and so does dust n stuff
