Rough Ride After Lift
Discussion in 'Suspension' started by goldentaco03, Aug 8, 2018.
  1. Aug 8, 2018 at 9:33 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    '04 4cyl Xtra Cab no extra weight in front or rear
    265/75r16 (I think) Duratracs
    I replaced by 10+ year old saggy suspension last year with 5100 lift with an aal in the rear. Got a the expected amount of lift all around and am more than happy with how it looks. However the ride is extremely stiff and jarring and the truck doesn't seem to soak up bumps in the road at all. I do still have my sway bar connected, because I daily drive this truck and need it to handle well. What are my options for fixing this? Also is it possible to lower the front shocks one notch, my CVs are taking a beating?
  2. Nov 24, 2020 at 6:55 AM
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    Did you ever figure out your issue?
  3. Nov 24, 2020 at 6:57 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    It says right on the website that’s it’s not for 4 cyl trucks.
    71tattooguy and tcjacado like this.
  4. Nov 24, 2020 at 9:32 AM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    Literally, on the site it says if you have a 2.7L truck they don't recommend the lift due to the harsh ride.
  5. Nov 24, 2020 at 9:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    Replacing it with the proper parts is the best solution.
    Of course. It will help the ride by reducing preload too. But likely not enough to make you happy, and you'll reduce your 'look' as well.
  6. Nov 24, 2020 at 9:45 AM
    Tacotruck7
    SoCal
    He just needs different coils. Rock some OME 880's and sell off the other coils.
  7. Nov 24, 2020 at 9:48 AM
    eon_blue
    eon_blue Most Improved Member
    Thread is a couple years old but yeah...620lb coils on a 4cyl truck without any added armor weight is gonna suck real bad.
    goforbroke123 and tcjacado like this.
  8. Nov 24, 2020 at 10:26 AM
    goldentaco03
    Liam
    NJ
    Yeah coils are too stiff, I knew that going in. Just didn’t know how stiff they would be. Might also be some worn body mount bushings, cause I have a clunk a haven’t been able to track down and it doesn’t seem to be suspension related. They did break in after I put about 15k miles on them, but it is still stiff. It rides like a truck what can I say, not gonna complain about it cause I’m not daily driving it right now. But when I was daily driving it, well, let’s just say a 20 year old truck isn’t gonna be a great daily driver regardless...
    I’ve been planning to put a bumper and winch on for years now but have been busy with school and now starting work. That should make it ride a bit better. I also did send an email to Toytec and sent them a video of what I was experiencing. They said it seemed pretty normal and expected for a 2.7L
    71tattooguy likes this.
  9. Nov 24, 2020 at 10:32 AM
    goldentaco03
    Liam
    NJ
    I also still have my sway bar on which isn’t great on trails and gravel
  10. Nov 24, 2020 at 10:36 AM
    eon_blue
    Bumper and winch should really help, but really a 620lb coil is more for a v6 with a bumper and winch. It might still be stiff even after you add the weight but it will definitely help.
  11. Nov 24, 2020 at 10:45 AM
    goldentaco03
    Liam
    NJ
    How’s that possible though? The engines are pretty close in weight. 420lbs for the 5vz and 381lbs for the 3rz...not sure if that’s a fully dressed engine or not
  12. Nov 24, 2020 at 11:16 AM
    eon_blue
    Probably not then, I didn't realize the two were that close in weight
  13. Nov 24, 2020 at 11:31 AM
    goldentaco03
    Liam
    NJ
    Right? That's why I was initially confused when I bought it..they're close in weight and I can't think of anything else the V6 would have that the 4cyl doesn't. Maybe 4wd...Auto vs manual??
  14. Nov 24, 2020 at 12:22 PM
    eon_blue
    There could be more that goes into the front end weight yeah, but the difference isn't that big...that being said I think a 620lb coil is even pretty stiff for a 6cyl let alone a 4cyl. I have 600# coils on my Kings and they are pretty stiff even with a front bumper + skids.
    Ride quality is subjective though and everyone has a different feel for what they like, once you add weight to your front end it will help. And you can decide from there if it's still too stiff or not
