Rough ride
Discussion in '1st Gen. Tacomas (1995-2004)' started by Poteet, Jan 31, 2015.
  1. Jan 31, 2015 at 3:26 PM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    Hey guys
    I have searched this forum, as well as others with no results. Forgive me if this is beating a dead horse.
    I have a 97 Tacoma, 92000 miles. I just replaced the shocks and struts and it still rides rough. I know it is a truck, but I've owned it since new and it should be smoother than this.
    Any help would be appreciated.
  2. Jan 31, 2015 at 3:39 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    how many PSI are you running your tires at? any lift? spacers? blocks?
  3. Jan 31, 2015 at 3:40 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    cheap chonese tires?
  4. Jan 31, 2015 at 3:42 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    What shocks/struts? What leaves and springs up front, how many miles? It is a truck...
  5. Jan 31, 2015 at 3:46 PM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    50 lbs. No Lift, No spacers all stock. Good tires. Goodyear Wrangler RT/S. Monroe Sesa-trac shocks and struts. No shakes or anything, just rough over bumps, even manhole covers etc…..
  6. Jan 31, 2015 at 3:48 PM
    pudge151
    Sean
    Connecticut
    50 lbs is way too much, go down to 30 and see how it rides
  7. Jan 31, 2015 at 4:10 PM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    Thanks,
    It says 50lbs. cold max on the tire, I figured it would be less rolling resistance, better gas milage etc…..
    I'm going to lower the pressure and go for a ride right now.
  8. Jan 31, 2015 at 4:12 PM
    pudge151
    Sean
    Connecticut
    yeah that's max pressure for tire, check the plaque on the door frame of your truck it should tell you recommended tire pressure. I think 30 is a good start point
  9. Jan 31, 2015 at 4:35 PM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    Thanks again
    I went to 35# and it is way better, will go to 30# in the a.m.
  10. Jan 31, 2015 at 5:10 PM
    pudge151
    Sean
    Connecticut
    great news man. love a quick, easy and FREE fix!!!
  11. Feb 1, 2015 at 7:59 AM
    pudge151
    Sean
    Connecticut
    Poor guy. Comes to TW cuz he's truck rides rough. Let's some air out of his tires and now he'll be spending his paychecks on mods and improvements haha. That's how I got hooked. Came here searching for an answer to simple question and I'm on my second taco that I've dumped money into
  12. Feb 1, 2015 at 9:27 AM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    So………………What's wrong with that?
    I bought my truck new in 97 and it has been a great truck.
    I just replaced both O2 sensors and fuel filter, 92,000 miles.
    I plan on doing the timing belt, water pump soon, after that? Who knows.
  13. Feb 1, 2015 at 9:55 AM
    pudge151
    Sean
    Connecticut
    Nothing wrong with that at all man just messing around
  14. Feb 1, 2015 at 9:58 AM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    I know, no offense taken.
  15. Feb 1, 2015 at 9:59 AM
    pudge151
    Sean
    Connecticut
    You air down to 30 psi ? How's the ride?
  16. Feb 2, 2015 at 1:56 PM
    Poteet
    Poteet [OP] Member
    Denver CO
    97 Tacoma
    None
    Much more civil!
  17. Feb 2, 2015 at 2:01 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Time for a SAS.
  18. Feb 2, 2015 at 2:06 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
  19. Feb 3, 2015 at 9:04 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Lol damn, next time go by the PSI on the doors, not what the tire says :)
    The rear should be 29, front 31 psi
  20. Feb 3, 2015 at 10:19 AM
    a.smo
    Aaron
    PHX, Az
    Just keep an eye on wear. I need to fill my front tires up more to make the wear even. I'm sitting at 34 right now in the front and 32 in the rear. It's barely noticeable bit if I can fix it I will.
