Rough Shifting, Especially When Cold (5spd.)
Discussion in '1st Gen. Tacomas (1995-2004)' started by DefyInertia, Dec 30, 2007.
  1. Dec 30, 2007 at 6:15 PM
    DefyInertia
    DefyInertia [OP] Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    I searched around and didn't find much so...
    I've got a 2001 5-Speed manual that has a fairly hard time shifting into first (takes some force) and just outright crunches into second unless a wait about 2 seconds with the clutch in before moving from 1 to 2.
    Again, these problems are worst when cold but never entirely go away. Is there something I can rip open and lube and/or adjust or are these symptoms of something much worse?
    Thanks!
  2. Dec 30, 2007 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may be able to try a synthetic lube for your 5 speed gearbox.......maybe something like mobil1 mt90 or something, as it may free up your shifts and make them smoother.
  3. Dec 30, 2007 at 9:29 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    another poss is the clutch isnt fully engaging right away...check fluid level and possibly bleed the slave cylinder once just to make sure no air bubbles... they bleed just like brakes small screw on cylinder...then of course keep the clutch master cylinder full
  4. Dec 31, 2007 at 1:54 PM
    LHAHN07
    LHAHN07 Active Member
    Pennsylvania
    02 Stepside TRD 4x4 SR5
    AEM intake, Magnaflow exhaust, Summit Racing leveling kit, Westin stanless steel Bull Bar, Line-X bedliner, B&M shifter, Performance Products stainless sidesteps, grey wire mod, more parts on the way!
    I have the same basic problem with my 02. My second gear doesn't crunch though. I changed my tranny and transfer case lube to Redline synthetic MT90 and it made no difference...:(
  5. Dec 31, 2007 at 8:53 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    350 sounds right, try bleeding them first.
  6. Jan 2, 2008 at 10:44 AM
    96Tacoma4x4
    96Tacoma4x4 Well-Known Member
    Memphis, TN
    96 xcab 4x4 LX stock
    32x11.50 and K&N filter drop in
    My 96 has always done the hard 1st gear when cold since day one. Just that 1 time going in to 1st to start off or I'll have to come to a complete stop before putting it in 1st, I try not to force it in 1st. After that it will shift just fine. It's annoying but I guess I got used to it driving it so many years.
  7. Feb 10, 2008 at 7:30 PM
    Tug
    Tug Active Member
    4X4 Access Cab
    Stock
    My 02 has the problem as well and its usually worst when its cold. Since Im having other issues with the clutch/transmission I honestly thought about just having my mechanic put in a new clutch kit. I dont know what to do now.
  8. Feb 12, 2008 at 6:37 AM
    a31gun
    a31gun Member
    Norman, OK
    01 SR5 4x4
    3", Blisten 5100's, Leer shell, Deckplate w/ K&N, Hella 500FF's in grill, 265 BFG AT's,
    01 with same prob, actually noticed it today. Its about 25 degrees out there. I have to almost completly stop the truck to get it into first. I Just relaplaced the Slave and Master about 5 weeks ago.
  9. Feb 12, 2008 at 5:55 PM
    Tug
    Tug Active Member
    4X4 Access Cab
    Stock
    Update....
    I took my truck into the dealer today, after arguing with everyone there they finally agreed to pay for a new clutch kit. I should get the truck back tomorrow (Wednesday) I'll post on whether a new clutch fixed the problem.
  10. Feb 26, 2008 at 3:33 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    My 04 was fine until I had a fluid change done all around my truck. We used the proper gear oil and stuff for everything, and now, I've got the difficult 1st gear. I have to be at a complete stop, and when it's cold, even then I almost need a crowbar for help.
    On a side note, I've also got this funny noise- when you push in the clutch, it makes a groaning noise unless I get underneath and spray some wd40 into the area where the cable and arm go into the tranny case. (Not sure of the proper part names)... then the noise goes away for about a month, then comes back. The arm is rusted to hell and looks like the boot might have come away from the housing at some point before I bought it. Irritating as hell, but I'd need to spend a ton of cash for a proper fix, so I'll just get a case of WD40 and live with it for now.
