Rough Start Up - Engine Sputtering Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lightgrenade, Jul 30, 2017.
  1. Jul 31, 2017 at 10:33 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    My 2nd gen did this about once a month. My 3rd gen did it just the other day.
    Isn't there some kind of fuel system thing that runs when the truck is off?
  2. Jul 31, 2017 at 11:34 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Fuel Pressure Evap system makes a noise a couple of hours after you don't drive but its to balance out the air pressure in the tank. It really has nothing to do with a warm engine..
  3. Jul 31, 2017 at 12:01 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    I ask because I'd go out in the garage and hear it running, then the next morning the truck would start like that.
  4. Jul 31, 2017 at 3:08 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I'll record my "cold start" after work. and when its warm.
  5. Jul 31, 2017 at 3:08 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    Here's a good question, do you notice a difference in startup between an empty tank and a full tank?
  6. Jul 31, 2017 at 3:16 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    No. But never really paid attention
  7. Jul 31, 2017 at 3:22 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    If there is, its either the fuel pump or the high pressure fuel rail system.
  8. Jul 31, 2017 at 4:54 PM
    lightgrenade
    lightgrenade [OP] Well-Known Member
    2017 TRD OR
    I don't think so, I just filled up and it was happening before and after. Update: Dealership updated software and after couldn't recreate the stutter. I'm not sold on a software issue causing the problem but I guess I'll find out within the next day or so.
    shakerhood likes this.
  9. Jul 31, 2017 at 6:54 PM
    lightgrenade
    2017 TRD OR
    Definitely didn't fix it. Sounds just as bad now.
  10. Jul 31, 2017 at 7:13 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Woo hoo!
    A problem I don't have!! :bananadance::broccoli::dancingbacon::kona::jellydance:
    SandyTaco4x4 and Rotekk like this.
  11. Jul 31, 2017 at 7:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would try going to a different Dealer, something is not right with that.
  12. Jul 31, 2017 at 7:32 PM
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    ... yet.
    :devil:
  13. Jul 31, 2017 at 7:36 PM
    lightgrenade
    2017 TRD OR
    Lol. He’s right. Thought I had a unicorn then 10k struck. Bewaaaaarrreeeee!!!!
    over60 likes this.
  14. Jul 31, 2017 at 8:00 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    This sounds EXACTLY like my 2nd gen...
  15. Aug 1, 2017 at 7:26 AM
    #35
    lightgrenade
    2017 TRD OR
    Update #2 - Started reading post about engine sputtering and found some information on running higher octane fuel. I've run 93 octane since I bought the truck in Dec and really never had a problem. I'm lucky enough to have a job that pays for my gas and thought why not run the good stuff. From the link below, user GIG mentions his experience running premium and how it affected his start up. I went back to the dealership and spoke to the mechanic. I mentioned my octane to the mechanic in passing and he immediately mentioned this. He said that the 02 sensor was reading additional oxygen at first and was creating the sputter. Makes sense that it takes time for the issue to reoccur due to it needs time for the fuel to give off additional evaporates. I'll switch back to regular and update later.
    nevadabugle likes this.
  16. Aug 1, 2017 at 8:18 AM
    #36
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Guaranteed, 100%, that will not solve this. This is the problem with internet conjecture....and your mechanic is using your theories to avoid troubleshooting the real problem.
    The hammer and shakerhood like this.
  17. Aug 1, 2017 at 8:30 AM
    #37
    lightgrenade
    2017 TRD OR
    Good chance you could be right... I didn’t mention anything but running premium though. Last thing I want is to keep going back if it continues. They monitored the fuel pressure while running and everything was steady. It would be pretty silly that a new vehicle would have issues just running premium in a hotter environment. What would make more sense if there was an issue with the mechanism that should bleed out that ‘extra’ pressure...
  18. Aug 1, 2017 at 8:47 AM
    #38
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Given this is direct injection under tons of high pressure, I'd say that pressure probably is bleeding out over time either due to leaking pressure regulator, injectors, or a fuel pump is slow to prime. That delay in building back up the pressure is the slow crank, but once running the pressure would appear fine, so your mechanic is looking at the wrong thing.
    Honestly, I'd request another tech on the job, or if you're not comfortable asking for that, take it to another dealership.
  19. Aug 1, 2017 at 8:55 AM
    #39
    lightgrenade
    2017 TRD OR
    Thanks for the advice. My knowledge on these truck are limited so I appreciate the input. May try another dealership.
    Edit- at new dealership now. Like Scooby mentioned, this mechanic doubts it has anything to do with fuel.
  20. Aug 1, 2017 at 12:15 PM
    #40
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    In my 2006 Taco, I was able to turn the key "on" and I think I could hear the fuel pump pressurize the system.
    How about pushing button without foot on brake....wait a second or 2 and then start truck....
    If that makes a difference, would that not point to slow fuel delivery...??
    I am no mechanic, but this theory does make some sense to me..!
    James_Bond likes this.
