Rough Start Up - Engine Sputtering Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lightgrenade, Jul 30, 2017.
  1. Aug 1, 2017 at 12:41 PM
    #41
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Yeah, priming the pump would help, unless the source of the leak is an injector that's leaking into the cylinder/manifold and then priming won't help at all because the problem is an overly rich/flooded condition. The way it's chugging on that start, I'm starting to think that might be it. The last vehicle I had that sounded like that the o-ring on an injector in a side feed rail I had just rebuilt got pinched, and it was dumping fuel into the cylinder. Sounded JUST like that chucking into a really slow, hesitant start.
    And if that's it, you need to change your oil immediately too because you're dumping fuel into the cylinder which is washing down the cylinder walls into your oil and diluting it, reducing lubrication and protection.
    over60 likes this.
  2. Aug 1, 2017 at 4:39 PM
    #42
    lightgrenade
    lightgrenade [OP] Well-Known Member
    2017 TRD OR
    Dealership 2 was able to recreate and record a fuel pressure leak. They are opening a case with corporate for additional support. They are leaning towards one of the fuel pumps. @Yzkiley
  3. Aug 1, 2017 at 5:11 PM
    #43
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    "one of the fuel pumps"... how many do we have..?? I thought we had only one..!
    Good luck... hope it gets fixed for ya..
  4. Aug 1, 2017 at 5:13 PM
    #44
    lightgrenade
    2017 TRD OR
    Think there may be a small one in the tank.
  5. Aug 1, 2017 at 5:14 PM
    #45
    Scooby24
    Greg
    2017 DCSB OR 4X4
    We have two fueling systems but even in direct injection only the hpfp is a mechanical pump. There's still an electric pump in the fuel tank.
  6. Aug 2, 2017 at 6:17 AM
    #46
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I wonder how one could determine whether there is a fuel pressure leak based on OBD data? given the chirping sounds and how high pressure that one pump runs I have always had concerns around fuel delivery in these trucks but don't really know what to look for / how to correlate.
  7. Aug 2, 2017 at 6:36 AM
    #47
    Scooby24
    Greg
    2017 DCSB OR 4X4
    you can't, they'd have put a pressure tester on the fuel rail. About the only way you'd have a potential marker for a constant pressure problem would be seeing huge positive LTFT values and/or learned knock correction.
    Fuel pressure can be extremely difficult to troubleshoot. I had a forged EJ25 Forester that I chased my tail on for some time with surging in power delivery after having installed ID 1000cc injectors and fuel rail. Turned out, the injectors were so large, that pulse width had to be so narrow in low load conditions that the pulses were wreaking havoc on fuel pressure which caused giant pulses of pressure that would create harmonic waves and cause momentary lean spikes in specific cylinders that, under just the right rpm/load, would end up creating surging power (not unlike what we have felt on our trucks). I datalogged the shit out of that tune and tried changing a LOT of things that never put a dent in the behavior.
    I found it by throwing on a pressure gauge that I rigged to a long hose that I could then mount in the cabin and go for a drive. The needle would bounce back and forth so fast it was blurred into a +-15 psi wave at that RPM range.
    Here's some videos I took of what it looks like at idle before I fixed it. Adding fuel line dampers to the beginning and end of the fuel rails resolved it entirely. Listen to the difference in sound!
    lightgrenade[OP] likes this.
  8. Aug 2, 2017 at 6:53 AM
    #48
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^This^^ I would also check and clean the battery terminals if needed and do a deep trickle charge on my battery, the longer the charge (like over night or the weekend) and lower the amp setting the better
    Cheers!
    Edit: I do the trickle charge once a month on all my vehicles
  9. Aug 2, 2017 at 6:55 AM
    #49
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are gdi engines more susceptible to changes in rvp or the 'wrong' rvp?
    I've read it can vary from 7-10 psi...
    Does E10 have different vaporization characteristics than E0?
  10. Aug 2, 2017 at 7:04 AM
    #50
    Scooby24
    Greg
    2017 DCSB OR 4X4
    That's above my pay grade. I can speak to fuel line pressures but when talking about RVP, you're getting into fuel properties that I know nothing about.
  11. Aug 2, 2017 at 9:17 AM
    #51
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    I know this doesn't help but my 2nd gen would do that about once every couple weeks since new. Never got it figured out before I traded it in at 80k miles.
    69others and shakerhood like this.
  12. Aug 2, 2017 at 5:27 PM
    #52
    lightgrenade
    2017 TRD OR
    Update: Dealership said Toyota wants them to run some additional test. The Service Rep said he wasn't sure on the specifics but involves isolating fuel lines for testing... Still no fix proposed and another day in a Corolla.:anonymous:
    shakerhood likes this.
  13. Aug 2, 2017 at 5:31 PM
    #53
    69others
    69others Well-Known Member
    Dang when I know I'm going to be sitting somewhere for a while I bring something constructive to do with my time.
  14. Aug 2, 2017 at 5:49 PM
    #54
    69others
    Holy shinola a 2nd gen actually having a problem like a 3rd gen ?
    Say it ain't so.
    Smitty you fainted yet ?
    Where are the 2nd gen white knights to the defense ?
    SandyTaco4x4 likes this.
  15. Aug 3, 2017 at 5:43 PM
    #55
    lightgrenade
    2017 TRD OR
    Update : Toyota decided to replace the pump in the tank. Part should be in tomorrow and installed by the afternoon.
    shakerhood and James_Bond like this.
  16. Aug 3, 2017 at 5:49 PM
    #56
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    OBDII is open so a manufacturer can add their own data codes and also relay analog data to a computer. The dealer might have graphed out the pressure data and saw the pressure was lower than spec.
  17. Aug 3, 2017 at 8:29 PM
    #57
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Hopefully that solves the issue for good.
  18. Aug 4, 2017 at 12:05 PM
    #58
    lightgrenade
    2017 TRD OR
    They received the pump and started installation. During they had issues pulling off a hose and ended up gnarling it up so much they have to replace it. Have to wait one more day now for the new hose to come in to finish the install.
  19. Aug 5, 2017 at 10:59 AM
    #59
    lightgrenade
    2017 TRD OR
    So all is finished up with the pump in the tank repair. Replacing the pump had no affect on the sputtering issue. Next step is to wait until Monday to update Toyota Corp and see what they want to do next. 1 day for them to decide, 1 day to get the part, and 1 day to fix so best case scenario I'll have my truck Wed evening.
  20. Aug 6, 2017 at 12:50 PM
    #60
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    So far to date I've changed
    fuel pump
    fuel pressure regulator
    All injectors
    cam position sensor
    Crank position sensor
    fuel pump relay
    Long start remains
