Rough Start Up - Engine Sputtering Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lightgrenade, Jul 30, 2017.
  1. Aug 6, 2017 at 2:13 PM
    #61
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Does your have an online fuel filter? What about spark plugs?
  2. Aug 6, 2017 at 6:56 PM
    #62
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    No inline filter and I change plugd every 30k.
  3. Aug 6, 2017 at 7:28 PM
    #63
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Tried swapping around coil packs? Sometimes changing around firing order on a bad pack can change behavior which would indicate if one needed to be replaced.
    Radarninja likes this.
  4. Aug 7, 2017 at 5:33 PM
    #64
    lightgrenade
    lightgrenade [OP] Well-Known Member
    2017 TRD OR
    Latest update: Dealership is now going to install new injectors. Parts in tomorrow.
    shakerhood, Radarninja and The hammer like this.
  5. Aug 7, 2017 at 5:53 PM
    #65
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Crossed fingers for ya..!!
    lightgrenade[OP] and The hammer like this.
  6. Aug 7, 2017 at 6:21 PM
    #66
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    All of them; port and direct?
    shakerhood likes this.
  7. Aug 7, 2017 at 6:28 PM
    #67
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    IDK if you know how lucky you R lol!
    Dealers don't usually bother with issues like this, they rather just repllace something they know is bad.
    This is very time comsuming work and at shop labor rates well over $$100 an hr. it's not profitable to engage in guess work.
    Having said that I can't tell you how many times an issue like this turned out to be something simple such as a bad battery or poor terminal contact.
    Hope they get you right, and share with the TW comunity the issue casing the fault, as it may help the next guy who may not be so lucky to have a dealer willing to help out
    Cheers
  8. Aug 7, 2017 at 6:56 PM
    #68
    lightgrenade
    2017 TRD OR
    Honestly I may have not pushed the issue if not for some comments on this thread. I agree that I am pretty lucky the 2nd dealership pushed pretty hard and opened a case with Toyota. Opening the case is Most likely why they are continueing to resolve the problem. Hopefully I can post a nice [resolved] on the title of the thread soon. I’ll keep everyone updated.
  9. Aug 7, 2017 at 6:59 PM
    #69
    lightgrenade
    2017 TRD OR
    Said all of them. Toyota Corp said pressure is leaking from somewhere. They originally thought it was the tank fuel pump. I guess the other end of that line are the injectors...
    The hammer likes this.
  10. Aug 10, 2017 at 8:54 AM
    #70
    lightgrenade
    2017 TRD OR
    [RESOLVED] So far replacing the injectors has fixed the issue. See parts list below. [​IMG]
  11. Aug 10, 2017 at 6:42 PM
    #71
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Nice! Now, get them to change the oil too because you were dumping fuel into your cylinders. With injector insulator that sounds like they replaced the direct injectors, not port injectors.
  12. Aug 11, 2017 at 7:26 AM
    #72
    The hammer
    They got you going, awesome dealership!
    That seems to be a rare issue at least to me, I don't recall seeing many complaints on it as the system is pretty robust and proven.
    Thanks for the update
    Cheers
  13. Jan 9, 2018 at 6:08 PM
    #73
    lightgrenade
    2017 TRD OR
    Thanks again for all the input
    SandyTaco4x4 likes this.
  14. Jan 9, 2018 at 6:09 PM
    #74
    lightgrenade
    2017 TRD OR
    Still running strong a few months later.
  15. May 11, 2018 at 6:25 PM
    #75
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    Digging up an old thread. I just had this issue once, at some other times it seem like a weak crank indicating a possible battery issue. How reliable was this to repeat and has anyone else had this exact issue?
  16. Oct 28, 2019 at 6:04 AM
    #76
    gti2taco
    gti2taco Well-Known Member
    Brian
    Va Beach
    14 trd offroad, stock
    I have the same issue and have a new battery. The weather here changed drastically and I started getting the problem again. I am going to attempt the stealership route and see how that goes.
  17. Jan 18, 2021 at 7:04 PM
    #77
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    huh. I just now experienced this. i have 95k miles on 17 trd-or. It happened 3 separate times over the weekend. My buddy and I figured it was some fuel system issue. possibly leaking somewhere.
    Is replacing the injectors the known fix? Wondering how hard it is to replace the injectors on these trucks and if I could just do them myself.
  18. Jan 18, 2021 at 7:06 PM
    #78
    ginseng27
    '17 DCSB OR
    not enough.
    I am also curious that maybe I got some subprime fuel somehow and that's causing startup issues. :/ I'll have to get some good fuel through and see if taht helps.
  19. Jan 18, 2021 at 9:48 PM
    #79
    Radarninja
    Northern California
    06 taco
    Replacing injectors is easy however, it didn’t fix my issue.
    I’m 46% sure that mine was fixed by a new mass air flow sensor.
    I was Shotgunning parts at the time.
    Was not injectors or fuel pump for me,
    for sure.
    Good luck and let us know
  20. Jan 21, 2021 at 8:30 AM
    #80
    ginseng27
    '17 DCSB OR
    not enough.
    Hmm...I'm about to start shotgunning parts really soon. This is really annoying. Happened about an hour ago. It's really inconsistent. The truck will sit overnight and start without issue...then it'll sit for like 2 hours and then have trouble starting.
    I'm gonna clean the MAF sensor here in a little bit. maybe that'll help. I have to replace my spark plugs here pretty soon anyways so maybe i'll do that a little sooner than not.
