Round 8 - projector retrofit group buy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by omac5, May 21, 2012.
  1. May 21, 2012 at 2:54 PM
    omac5
    omac5 [OP] Well-Known Member
    Marqus
    South Texas (MISSION)
    2011 4x4 SR5 Magnetic Gray
    SUSPENSION: icon front & rear icon UCA Toytec 2" AAL
    Got a reply from andrew The Retrofit Source and round 8 is a go, I will also link this with the 4runner forums who is showing interest there as well so we can get orders faster.
    TRS website: The story behind The Retrofit Source Inc
    here's the basic if we want to get this round 8 going.
    -stage III OR stage IV complete kits
    -no CBI's/SVS discount
    -25 orders = 25% off
    -ships when 25 orders are completed
    -discount code will be posted once 4runner and tacomaworld forum has listed 25 people committing to buy
    1.omac5 - BI-XENON FX-R STAGE III KIT
    2.
    3.
    4.
    5.
    lets get number 8 going!!
  2. May 21, 2012 at 3:03 PM
    hbryanlopez
    hbryanlopez Well-Known Member
    herby
    mcallen, tx
    black out headlights bilstein 5100s toytec 2" aal procomp 7089 nitto terra grapler 285/70/17
    2.hbryanlopez - BI-XENON MORIMOTO MINI STAGE III KIT (D2S)
    3.
    4.
    5.
  3. May 21, 2012 at 3:05 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    nice another GB
  4. May 21, 2012 at 3:19 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    I'm a little new to the projector retrofit's. What is involved regarding installation?
  5. May 21, 2012 at 3:21 PM
    AsianAnts
    AnT
    depends on the projectors being used... Morimoto Minis are relatively easy... open lights, mount projectors, aim, seal lights
    FX-Rs and some others require more work. Open lights, make hole bigger on bowl, temporarily mount and aim projectors, once aligned, mount projectors permantely, seal lights.
    there are many threads showing what is involved in an installation for the various projectors. Search and you shall find em.
  6. May 21, 2012 at 3:24 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Gotta love the guys at TRS :D
    perhaps you or me or OP or someone should make a post with frequently asked questions answered to copy into the OP to avoid the redundant reposts. . . Just a suggestion! GL
  7. May 21, 2012 at 3:27 PM
    AsianAnts
    AnT
    i can post some links for FX-R retrofits, Mini, and blazer fogs. when i get some free time ill search
    TRS staff are great indeed!
  8. May 21, 2012 at 3:46 PM
    omac5
    Marqus
    ooops wrong place to put this up..sorry mods
  9. May 21, 2012 at 5:11 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Grant
    Seattle WA
    '12 DCLB 4x4 FTMFW
    Interested. Any advice on what kit to get?
  10. May 21, 2012 at 6:22 PM
    Braunschwaga
    Braunschwaga Well-Known Member
    A-A-Ron
    Kauai, HI
    15' Tacoma TRD Off-Road
  11. May 21, 2012 at 6:26 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    A lot of people get the mini (H1 or D2S) because they're easiest to install
    FX-Rs are better quality but require free hand cutting of your light housing and a slightly more difficult aiming/securing process.
    Blazers are for fogs, you have to cut/rig it up custom, no plug n play or bake n reseal there.
    H4 headlights
    H10 fogs (H11 for 2012s) are the sizes you need and the harness will be the H4/9003 iirc
    H1 has been deemed a little brighter while D2S more even output. Most go with the H1 simply because its brighter but don't consider other factors. Matt and the guys at TRS mostly favor the D2S and I also like to point out that the larger shrouds fill our headlights better than the mini H1 and there is a greater selection.
    3000k is yellowish and good for fogs for its ability to cut through adverse weather
    4300k is like sunlight or stock color headlights and has the highest lumen count (brightest) of the available options
    5000k will be whiter and is the highest TRS recommends.
    6000k is also very white with a tiny bit more blue
    Any higher temp is stupid because you lose light output and fatigue your eyes and others.
    I always say 4300k is the way to go but can see how white/5000k has an appeal
    The upside to a projector retrofit vs cheap hid bulbs in your stock light housing is mainly that it is higher quality and has a clean cut off line. Also helps that it is legal.
    I can't think of anything else off the top of my head but that should be a good starting point for anyone who wants to start researching these.
  12. May 21, 2012 at 7:28 PM
    omac5
    Marqus
    awesome! thanks for the info..
    guys i posted this in the wrong forum, please see this forum for the correct one.http://www.tacomaworld.com/forum/group-buys/220939-round-8-projector-retrofit-group-buy.html
    admin can you please close. thanks.
