RPB Question and fitment
Discussion in 'Wheels & Tires' started by sledneck, Apr 25, 2011.
  1. Apr 25, 2011 at 12:39 PM
    sledneck
    sledneck [OP] Active Member
    Northern Maine
    2011 TRD Sport DC
    MBRP Stainless Duels, AFE CAI Stafe 2, lBilstein 5100's, 886's, smittybuilt Nerf Bars, UWS box, 6000K HID's, Grillcraft grille, Switchback LED signals and DTRL's, 20% tint,
    I have a 11 TRD Sport DC short bed I just purchased yesterday. I am looking at getting 18X9 RBP(Rolling Big Power) 94R wheels. There are two I found for $270 a piece shipped. Both are 18X9, one has -25 and the other has 10 offset and both with a center bore of 78.10. I am looking for more of a "deep dish" look if I can get it, but still want to fit right and handle correctly. I am probably going to stick with 265 wheel size or at most 275.
    Any help on which one -25 or +10 offset will best fit my needs will be greatly appreciated.
    Respectfully
  2. Apr 25, 2011 at 7:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    For a 9" wheel, +10 offset is 5.4" backspacing and -25 is 4.0" backspacing. If you are only planning o running 265s then the +10 will be fine.
  3. Apr 26, 2011 at 6:16 AM
    sledneck
    Northern Maine
    2011 TRD Sport DC
    So, either one will fit with no issues? And I thought that -25 offset and the 4.0" backspacing will give deeper looking rim and not stick out as far compared to the +10 offset with 5.4" backspacing?
    Thanks
  4. Apr 26, 2011 at 6:19 AM
    KPT
    09 Prerunner
    No the 4" backspacing will stick out 1.4" inches more than the 5.4". Some have reported rubbing out the outer edge of the tire with 4.0 backspaced rims.
    4.5" woud be ideal for either 265 or 285's, but the 5.4" is fine for the 265's you plan to run.
  5. Apr 26, 2011 at 7:11 AM
    sledneck
    Northern Maine
    2011 TRD Sport DC
    I agree that 4' backspacing will sitck out more but it will be a deeper dish rim correct? And would a spacer help and eliminate any chance or rubbing? I assume they make small spacers, 1/2 or 1 inch?
    I appreciate your patience! I just like checking and re-checking before a purchase
  6. Apr 26, 2011 at 7:55 AM
    KPT
    09 Prerunner
    I think the lip of the rim is a fixed size and they just increase/decrease the thickness of the mounting point to change the backspacing...not positive though.
    The kind of rubbing I was talking about (on the outer edge of the tire) would be made worse by a spacer, not better.
  7. Apr 26, 2011 at 11:12 AM
    sledneck
    Northern Maine
    2011 TRD Sport DC
    Gotcha! Funny thing is now I've found same rim 18X9 with -12 offset and 4.5 backspacing all four shipped for $1000. I think that will be perfect and run 265/65r18 like you are running.
    Thanks again for your knowledge
