rpm idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Feb 13, 2012.
  1. Feb 13, 2012 at 4:18 AM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    what should the idle be set at? 02 taco,3.4 is running at .500. seems like it should be higher. looking for some help from the guru's on this?
  2. Feb 13, 2012 at 4:20 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Mine idles around that as well. Hopefully its normal haha
  3. Feb 13, 2012 at 4:40 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Usually around 700-750 is pretty normal.
  4. Feb 13, 2012 at 5:21 AM
    tlh178
    terry
    lake huron/sag bay
    is there a part that has gone bad? or is there an adjustment screw some were that has to be made? i'm old school, back in the day were we had 4bl holley carbs were on a z28! this fuel injection is new for me.
  5. Feb 13, 2012 at 7:23 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    There is an adjustment screw/nut setup in front of the throttle body close to the end of the cable. On my 97, you tighten it, it eats more cable, and the idle rises. From what I have read, between 650-750rpm is normal. I would tend to think it's just an adjustment rather than a bad part since it's just low, rather than sputtering.
    On the other hand you might need a tune-up. Depending on what you've done lately, could try a Seafoam treatment, new plugs, TB clean, which should also clean out the IAC valve. Also check the PCV valve and make sure it isn't clogging up.
    That's how I would handle it ;)
  6. Feb 13, 2012 at 2:10 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I think mine runs around 500-600 at idle (3.4L)
    I think as long as the idle is consistent, and doesn't surge and sputter, you're probably okay.
  7. Feb 13, 2012 at 2:32 PM
    240andCounting
    240andCounting Member
    Taylor
    Columbia, SC
    98 tacoma Sr5
    New clutch at 238,000 (stage 1) 4 kenwood door speakers kenwood head unit
    mine idles at 500 also
  8. Feb 13, 2012 at 3:52 PM
    tlh178
    terry
    lake huron/sag bay
    i'll try doing the tb and iac. i have do everything else you have listed, plus i just did timing belt,water pump,tensonier pulley,other pulley and new thermo. month ago i put in new starter. truck has 275k and still run like a champ.
  9. Jul 15, 2012 at 7:39 AM
    sonnytris
    sonnytris Member
    san antonio tx
    2003 2wd
    I know its a old question but my 03 taco 2.4 has low idle . seen the adjustment for the cable two nuts over a holding bracket? and a nut and screw adjustment at the end of cable? or they both idle adjustmens? os is one a course and other a fine adjustment? there is a little looseness to the cable it moves before the truck reacts to me manuyally moving the idle cable ...well i am confused but can you make any suggestions
    sonny
  10. Jul 15, 2012 at 10:33 AM
    Yotacoma92
    Yotacoma92 TacoLover
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    Westin brush guard, smitty built nerf bars, roll bar, K&N air filter, Helo 17" Rims with 285-65-17 BFG KM2's, OME 2in lift springs, 0-2.5 lift Bilstein 5100 struts, OME 3in lift leaf springs, 5125 bilstein rear shocks, Projector HID headlights, Blacked corner lamps.
    Dont mess with the throttle cable, if you adjust that cable then all your doing is opening the butterfly valve more and in a few months time the computer will re-learn and change the idle to lower again, al you will be doing is dumping more fuel when you really dont need too. if your truck isnt sputtering or idling rough then dont worry about the idle, mine is about 550 and i have had no problems with it.
