rr diff lock saved me...
Discussion in 'Off-Roading & Trails' started by SpRuCe MiCa, Mar 16, 2012.
  1. Mar 23, 2012 at 12:34 AM
    #101
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    tip tronic lol, my friend has it in his GTI. moderately amusing. or! Paddle shifters...on the taco!
  2. Mar 23, 2012 at 12:41 AM
    #102
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I believe those still have torque converters, I'm referring to transmissions that use automatically shifted clutches, with a standard gear box behind them.
  3. Mar 23, 2012 at 2:58 AM
    #103
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
  4. Mar 23, 2012 at 2:46 PM
    #104
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Wow! Now I want to go back and read this whole thread!
  5. Mar 23, 2012 at 2:50 PM
    #105
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    Into drama are ya? :p
  6. Mar 23, 2012 at 3:19 PM
    #106
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Not going to bust balls that bad but just a little tip - trucks are much easier to pull out when they aren't in park :D
    Reverse lights.......look at them.....dude isn't even in reverse when getting tugged 1/2 the time lol
    m
  7. Mar 23, 2012 at 3:59 PM
    #107
    Plannerman99
    So Cal
    Well, thought I was going to find some entertainment, but lost my appetite for the thread before I could finish. Blech.
  8. Mar 23, 2012 at 6:22 PM
    #108
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looks like the correct line would have let you walk up that.
  9. Mar 23, 2012 at 6:34 PM
    #109
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    helped me on the beach to get over stuff everyone usually gets stuck on
  10. Mar 23, 2012 at 6:48 PM
    #110
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    locked front and rear on this climb..way steeper then it looks on video..the crawler before me was floundering pretty bad on his previous attempts but finally made it.. as seen on this video.
    i crawled right up no problem:D..
    note to David K..i was locked front and rear before i came into frame..no problems turning into the climb what so ever!!
    http://www.youtube.com/watch?v=CK33bzjXB1c
  11. Mar 23, 2012 at 7:33 PM
    #111
    Spoonman
    Jamie
    Alberta
    Monkeyproof, gotta ask. How are the 4:56 gears with your 35s? I got my 35s on Wednesday and I'm thinking of going with 4:56 gears. I've got an automatic, 5 speed. Is yours auto or standard?
  12. Mar 23, 2012 at 7:54 PM
    #112
    MonkeyProof
    SoCal- SGV
    i have the auto trans..
    i love the gears with my 35's. the difference is very noticeable in every aspect. on the highway you'll notice the trans shift points are better and more transparent. if you tow anything then you'll really be pleased with the 4.56's.
    on the trail you''ll notice an easier time with crawling over an obstacle or descending down something step..especially while in 4L
  13. Mar 23, 2012 at 8:17 PM
    #113
    Spoonman
    Jamie
    Alberta
    Good to hear that. I don't tow but I hail dirtbikes and camping gear often. I'm all excited, your truck is awesome. Do you have a build thread, sir?
  14. Mar 25, 2012 at 9:42 AM
    #114
    x2468
  15. Mar 25, 2012 at 1:36 PM
    #115
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Note to monkey proof... on slippery dirt (as we see in the video), no problem. I agree.
    On granite rock, big problem (same as being on pavement)... Wonder why Toyota puts a warning lable on the use of the locker for emergencies only? Because, some will use it because they have been told it doesn't affect steering.. and then they go over a cliff because they couldn't turn the truck soon enough when it was locked.
    A-TRAC Tacomas: Use A-TRAC when you are in low range... You probably won't need to also lock the rear... but it is there if the A-TRAC doesn't perform. A-TRAC does not hinder steering on hard surfaces...
  16. Mar 25, 2012 at 1:45 PM
    #116
    MonkeyProof
    SoCal- SGV
  17. Mar 25, 2012 at 1:47 PM
    #117
    MonkeyProof
    SoCal- SGV
    wtf are you talking bout :crazy::facepalm:are you saying that atrac works so well..that you shouldnt need a rear locker?!
  18. Mar 25, 2012 at 1:56 PM
    #118
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    What are you talking about? When turning on pavement there is a little tire squeeling and thats it. Maybe a very slight loss in turning radius. Why would people use full time lockers on a dd if it made them fall off cliffs?
  19. Mar 25, 2012 at 1:58 PM
    #119
    MonkeyProof
    SoCal- SGV
    that label says to " use only to free your stuck vehicle in an emergency escape from muddy road"
    so..unless you're stuck in a muddy road, while in an emergency situation.. you should not use your rear locker..according to that label you are always quoting :rolleyes:
  20. Mar 25, 2012 at 2:00 PM
    #120
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    What are you talking about? A locked rear WILL hinder your steering! Those DD with locked diff's handle like shit in the rain and you can spin out easily. I know, I drove one for years.
